Number entity refactoring to support unit conversion
NumberEntity
now supports temperature unit conversion following a similar pattern
as the unit conversion supported by SensorEntity
Temperature conversion will automatically be done for number entities with device
class set to temperature
to the temperature unit configured by the user.
To make this possible, custom component integrations should be updated to override
properties native_max_value
, native_min_value
, native_step
native_unit_of_measurement
, native_value
instead of max_value
, min_value
step
, unit_of_measurement
, value
and to override methods async_set_native_value
and set_native_value
instead of async_set_value
and set_value
The same renaming has been done for _attr_*
attributes as well as members of
NumberEntityDescription
In Home Assistant Core 2023.1, overriding async_set_value
, max_value
, min_value
set_value
, step
, value
, setting _attr_max_value
_attr_min_value
, _attr_unit_of_measurement
, _attr_step
, _attr_value
and
setting max_value
, min_value
, step
on instances of
is no longer supported.
