Deprecate hass.helpers usage
 · One min read
As of Home Assistant 2024.5, we deprecate the use of hass.helpers.
Using hass.helpers will issue a warning in the logs.
Authors of custom integrations are encouraged to update their code
to prevent any issues before Home Assistant 2024.11.
Starting from Home Assistant 2024.11, hass.helpers will be removed and will no longer work.
Integrations that use hass.helpers should be updated to import the functions and classes directly
from the integration package and pass the hass object as first parameter.
New example
from homeassistant.helpers.aiohttp_client import async_get_clientsession
async def async_setup(hass: HomeAssistant, config):
    """Set up the component."""
    client = async_get_clientsession(hass)
Old example
    client = hass.helpers.aiohttp_client.async_get_clientsession()
