Frontend component updates in 2026.5
· 4 min read
Component updates​
ha-progress-bar​
A new component replaces mwc-progress-bar in our codebase and is fully themeable. Check out this PR for a fully custom progress bar.
New component specific tokens:
--ha-progress-bar-indicator-color
--ha-progress-bar-indicator-background
--ha-progress-bar-track-color
--ha-progress-bar-track-height
--ha-progress-bar-border-radius
--ha-progress-bar-animation-duration
--ha-progress-bar-indicator-highlight-image
--ha-progress-bar-indicator-highlight-width
--ha-progress-bar-indicator-highlight-height
ha-switch​
ha-switch was migrated to webawesome. It now has many CSS properties to make customization easier. We also removed some tokens from the old switch:
Removed tokens:
--switch-unchecked-button-color
--switch-unchecked-track-color
--switch-unchecked-color
--switch-checked-button-color
--switch-checked-track-color
--switch-checked-color
--ha-switch-size
--ha-switch-thumb-size
--ha-switch-width
--ha-switch-background-color
--ha-switch-thumb-background-color
--ha-switch-background-color-hover
--ha-switch-thumb-background-color-hover
--ha-switch-checked-background-color
--ha-switch-checked-thumb-background-color
--ha-switch-checked-background-color-hover
--ha-switch-checked-thumb-background-color-hover
--ha-switch-border-color
--ha-switch-thumb-border-color
--ha-switch-thumb-border-color-hover
--ha-switch-checked-border-color
--ha-switch-checked-thumb-border-color
--ha-switch-checked-border-color-hover
--ha-switch-checked-thumb-border-color-hover
--ha-switch-thumb-box-shadow
--ha-switch-disabled-opacity
--ha-switch-required-marker
--ha-switch-required-marker-offset
ha-checkbox​
ha-checkbox was also migrated to webawesome and got new CSS properties. You can no longer use MDC tokens for it, but we added a set of tokens to customize the new checkbox.
--ha-checkbox-size
--ha-checkbox-border-color
--ha-checkbox-border-color-hover
--ha-checkbox-background-color
--ha-checkbox-background-color-hover
--ha-checkbox-checked-background-color
--ha-checkbox-checked-background-color-hover
--ha-checkbox-checked-icon-color
--ha-checkbox-checked-icon-scale
--ha-checkbox-border-radius
--ha-checkbox-border-width
--ha-checkbox-required-marker
--ha-checkbox-required-marker-offset
ha-textarea​
ha-textarea was migrated to webawesome and got new CSS properties. You can no longer use MDC tokens for it, but we added a set of tokens to customize the new textarea.
The API changed slightly. To make your textarea grow in size, set the resize prop to auto.
ha-adaptive-popover​
You might already know the (fairly new) ha-adaptive-dialog component. It combines a dialog and bottom sheet by showing a dialog on desktop and a bottom sheet on mobile. We added ha-adaptive-popover as the popover counterpart to the adaptive dialog. It shows a popover on desktop and a bottom sheet on mobile. It is based on ha-adaptive-dialog and is currently used in the tile card date picker feature.
Removed ha-fab​
ha-fab was removed, we use just a normal ha-button now, since the position styling was always done from the parent component.
Style updates​
Box shadow tokens​
We added new global box shadow tokens: --ha-box-shadow-s, --ha-box-shadow-m, --ha-box-shadow-l
But we also removed the old box shadow tokens:
--ha-color-shadow-light
--ha-color-shadow-dark
--ha-shadow-offset-x-...
--ha-shadow-blur-...
--ha-shadow-spread-..
Surface colors​
In the next release we plan to change the way we handle surface background colors. The tokens are introduced now but are just used for ha-tooltip.
New tokens:
--ha-color-surface-default
--ha-color-surface-low
--ha-color-surface-lower
--ha-color-surface-default-inverted
--ha-color-surface-low-inverted
--ha-color-surface-lower-inverted
