Sending data home
Once you have registered your app with the mobile app component, you can start interacting with Home Assistant via the provided webhook information.
The first step is to turn the returned webhook ID into a full URL: <instance_url>/api/webhook/<webhook_id>. This will be the only url that we will need for all our interactions. The webhook endpoint will not require authenticated requests.
If you were provided a Cloudhook URL during registration, you should use that by default and only fall back to a constructed URL as described above if that request fails.
If you were provided a remote UI URL during registration, you should use that as the instance_url when constructing a URL and only fallback to the user provided URL if the remote UI URL fails.
To summarize, here's how requests should be made:
  1. If you have a Cloudhook URL, use that until a request fails. When a request fails, go to step 2.
  2. If you have a remote UI URL, use that to construct a webhook URL: <remote_ui_url>/api/webhook/<webhook_id>. When a request fails, go to step 3.
  3. Construct a webhook URL using the instance URL provided during setup: <instance_url>/api/webhook/<webhook_id>.
Short note on instance URLs
Some users have configured Home Assistant to be available outside of their home network using a dynamic DNS service. There are some routers that don't support hairpinning / NAT loopback: a device sending data from inside the routers network, via the externally configured DNS service, to Home Asisstant, which also resides inside the local network.
To work around this, the app should record which WiFi SSID is the users home network, and use a direct connection when connected to the home WiFi network.
Interaction basics
Request
All interaction will be done by making HTTP POST requests to the webhook url. These requests do not need to contain authentication.
The payload format depends on the type of interaction, but it all shares a common base:
"type": "<type of message>",
"data": {}
If you received a secret during registration, you MUST encrypt your message and put it in the payload like this:
"type": "encrypted",
"encrypted": true,
"encrypted_data": "<encrypted message>"
Response
As a general rule, expect to receive a 200 response for all your requests. There are a few cases in which you will receive another code:
  • You will receive a 400 status code if your JSON is invalid. However, you will not receive this error if the encrypted JSON is invalid.
  • You will receive a 201 when creating a sensor
  • If you receive a 404, the mobile_app component most likely isn't loaded.
  • Receiving a 410 means the integration has been deleted. You should notify the user and most likely register again.
Implementing encryption
mobile_app supports two way encrypted communication via Sodium.
info
Sodium is a modern, easy-to-use software library for encryption, decryption, signatures, password hashing and more.
Choosing a library
Libraries that wrap Sodium exist for most modern programming languages and platforms. Sodium itself is written in C.
Here are the libraries we suggest using, although you should feel free to use whatever works well for you.
  • Swift/Objective-C: swift-sodium (official library maintained by Sodium developers).
For other languages, please see the list of Bindings for other languages. If more than one choice is available, we recommend using the choice most recently updated as well as most peer reviewed (a easy way to check this is seeing how many GitHub stars a project has).
We use the secret-key cryptography features of Sodium to encrypt and decrypt payloads. All payloads are JSON encoded in Base64. For Base64 type, use sodium_base64_VARIANT_ORIGINAL (that is, "original", no padding, not URL safe).
Signaling encryption support
There are two ways to enable encryption support:
  • During initial registration you set supports_encryption to true.
  • After initial registration you call the enable_encryption webhook action.
The Home Assistant instance must be able to install libsodium to enable encryption. Confirm that you should make all future webhook requests encrypted by the presence of the key secret in the initial registration or enable encryption response.
You must store this secret forever. There is no way to recover it via the Home Assistant UI and you should not ask users to investigate hidden storage files to re-enter the encryption key. You should create a new registration if encryption ever fails and alert the user.
A registration may not initially support encryption due to a lack of Sodium/NaCL on the Home Assistant Core side. You should always strive to encrypt communications if possible. Therefore, we politely request that from time to time you attempt to enable encryption automatically or allow the user to manually enable encryption via a button in your app. That way, they can attempt to first fix whatever error is causing Sodium/NaCL to be uninstallable and then have a encrypted registration later. Home Assistant Core will log exact details if Sodium/NaCL is uninstallable.
Update device location
This message will inform Home Assistant of new location information.
"type": "update_location",
"data": {
"gps": [12.34, 56.78],
"gps_accuracy": 120,
"battery": 45
KeyTypeDescription
location_namestringName of the zone the device is in.
gpslatlongCurrent location as latitude and longitude.
gps_accuracyintGPS accurracy in meters. Must be greater than 0.
batteryintPercentage of battery the device has left. Must be greater than 0.
speedintSpeed of the device in meters per second. Must be greater than 0.
altitudeintAltitude of the device in meters. Must be greater than 0.
courseintThe direction in which the device is traveling, measured in degrees and relative to due north. Must be greater than 0.
vertical_accuracyintThe accuracy of the altitude value, measured in meters. Must be greater than 0.
Call a service
Call a service in Home Assistant.
"type": "call_service",
"data": {
"domain": "light",
"service": "turn_on",
"service_data": {
"entity_id": "light.kitchen"
KeyTypeDescription
domainstringThe domain of the service
servicestringThe service name
service_datadictThe data to send to the service
Fire an event
Fire an event in Home Assistant.
"type": "fire_event",
"data": {
"event_type": "my_custom_event",
"event_data": {
"something": 50
KeyTypeDescription
event_typestringType of the event to fire
event_datastringDate of the event to fire
Render templates
Renders one or more templates and returns the result(s).
"type": "render_template",
"data": {
"my_tpl": {
"template": "Hello {{ name }}, you are {{ states('person.paulus') }}.",
"variables": {
"name": "Paulus"
data must contain a map of key: dictionary. Results will be returned like {"my_tpl": "Hello Paulus, you are home"}. This allows for rendering multiple templates in a single call.
KeyTypeDescription
templatestringThe template to render
variablesDictThe extra template variables to include.
Update registration
Update your app registration. Use this if the app version changed or any of the other values.
"type": "update_registration",
"data": {
"app_data": {
"push_token": "abcd",
"push_url": "https://push.mycool.app/push"
"app_version": "2.0.0",
"device_name": "Robbies iPhone",
"manufacturer": "Apple, Inc.",
"model": "iPhone XR",
"os_version": "23.02"
All keys are optional.
KeyTypeDescription
app_dataDictApp data can be used if the app has a supporting component that extends mobile_app functionality or wishes to enable the notification platform.
app_versionstringVersion of the mobile app.
device_namestringName of the device running the app.
manufacturerstringThe manufacturer of the device running the app.
modelstringThe model of the device running the app.
os_versionstringThe OS version of the device running the app.
Get zones
Get all enabled zones.
"type": "get_zones"
Get config
Returns a version of /api/config with values useful for configuring your app.
"type": "get_config"
Enable encryption
This requires Home Assistant 0.106 or later.
Enables encryption support for an existing registration
"type": "enable_encryption"
There are two errors you may receive:
  • encryption_already_enabled - Encryption is already enabled for this registration
  • encryption_not_available - Sodium/NaCL is unable to be installed. Cease all future attempts to enable encryption.
