Creating custom UI
Deprecated
This feature has been deprecated and is no longer supported. To add custom UI to Home Assistant, build a custom Lovelace card instead.
State card
If you would like to use your own State card without merging your code into home-assistant-polymer you can create your own implementation.
Put the element source file and its dependencies in www/custom_ui/ directory under your Home Assistant configuration directory.
For example if creating a state card for the light domain named state-card-my-custom-light put state-card-my-custom-light.html in www/custom_ui/.
That file should implement <state-card-my-custom-light> tag with Polymer.
In state-card-my-custom-light.html you should use <link rel="import"> to import all the dependencies not used by Home Assistant's UI. Do not import any dependencies used by the Home Assistant UI. Importing those will work in development: 1 mode, but will fail in production mode.
  1. In the customize: section of the configuration.yaml file put custom_ui_state_card: state-card-my-custom-light.
  2. In the frontend section use extra_html_url to specify the URL to load.
Example:
configuration.yaml:
homeassistant:
customize:
light.bedroom:
frontend:
extra_html_url:
- /local/custom_ui/state-card-my-custom-light.html
www/custom_ui/state-card-my-custom-light.html:
<script>
// show the version of your custom UI in the HA dev info panel (HA 0.66.0+):
const _NAME = 'My custom light';
const _URL = 'https://home-assistant.io/developers/frontend_creating_custom_ui/';
const _VERSION = '20180312';
if (!window.CUSTOM_UI_LIST) window.CUSTOM_UI_LIST = [];
window.CUSTOM_UI_LIST.push({
url: _URL,
version: _VERSION
</script>
<dom-module id='state-card-my-custom-light'>
<template>
<style>
</style>
<textarea>[[_toStr(stateObj)]]</textarea>
</template>
</dom-module>
<script>
class StateCardMyCustomLight extends Polymer.Element {
static get is() { return 'state-card-my-custom-light'; }
static get properties() {
return {
// Home Assistant object
hass: Object,
// inDialog is true if shown as more-info-card
inDialog: {
type: Boolean,
value: false,
// includes state, config and more information of the entity
stateObj: Object,
_toStr(obj) {
return JSON.stringify(obj, null, 2);
customElements.define(StateCardMyCustomLight.is, StateCardMyCustomLight);
</script>
tip
Some browsers don't support latest ECMAScript standards, these require a separate ES5 compatible file (extra_html_url_es5).
For more possibilities, see the Custom UI section on our Examples page.
More info dialog
Introduced in Home Assistant 0.69.
Similar to the custom State card, if you would like to use your own More info dialog you can create your own implementation.
Following a similar example, if creating a more info dialog a light named more-info-my-custom-light put more-info-my-custom-light.html in www/custom_ui/.
  1. In the customize: section of the configuration.yaml file put custom_ui_more_info: more-info-my-custom-light.
Example:
configuration.yaml:
homeassistant:
customize:
light.bedroom:
frontend:
extra_html_url:
- /local/custom_ui/more-info-my-custom-light.html
