Local add-on testing
The fastest and recommended way to develop add-ons is using a local Visual Studio Code devcontainer. We maintain a devcontainer for this purpose which is used in all our add-on repositories. This devcontainer setup for VS Code runs Supervisor and Home Assistant, with all of the add-ons mapped as local add-ons inside, making it simple for add-on developers on Windows, Mac and Linux desktop OS-es.
- Follow the instructions to download and install the Remote Containers VS Code extension.
- Copy the devcontainer.jsonfile to.devcontainer/devcontainer.jsonin your repository.
- Copy the tasks.jsonfile to.vscode/tasks.jsonin your repository.
- Open the root folder inside VS Code, and when prompted re-open the window inside the container (or, from the Command Palette, select 'Rebuild and Reopen in Container').
- When VS Code has opened your folder in the container (which can take some time for the first run) you'll need to run the task (Terminal -> Run Task) 'Start Home Assistant', which will bootstrap Supervisor and Home Assistant.
- You'll then be able to access the normal onboarding process via the Home Assistant instance at http://localhost:7123/.
- The add-on(s) found in your root folder will automatically be found in the Local Add-ons repository.
Remote development
If you require access to physical hardware or other resources that cannot be locally emulated (for example, serial ports), the next best option to develop add-ons is by adding them to the local add-on repository on a real device running Home Assistant. To access the local add-on repository on a remote device, install either the Samba or the SSH add-ons and copy the add-on files to a subdirectory of /addons.
Right now add-ons will work with images that are stored on Docker Hub (using image from add-on config). To ensure that the add-on is built locally and not fetched from an upstream repository, ensure that the image key is commented out in your config.yaml file (You can do that by adding a # in front of it, like #image: xxx).
Local build
If you don't want to use the devcontainer environment, you can still build add-ons locally with Docker. The recommended method is to use the official build tool to create the Docker images.
Assuming that your addon is in the folder /path/to/addon and your Docker socket is at /var/run/docker.sock, you can build the addon for all supported architectures by running the following:
docker run \
  --rm \
  -it \
  --name builder \
  --privileged \
  -v /path/to/addon:/data \
  -v /var/run/docker.sock:/var/run/docker.sock:ro \
  ghcr.io/home-assistant/amd64-builder \
  -t /data \
  --all \
  --test \
  -i my-test-addon-{arch} \
  -d local
If you don't want to use the official build tool, you can still build with standalone Docker. If you use FROM $BUILD_FROM you'll need to set a base image with build args. Normally you can use following base images:
- armhf: ghcr.io/home-assistant/armhf-base:latest
- aarch64: ghcr.io/home-assistant/aarch64-base:latest
- amd64: ghcr.io/home-assistant/amd64-base:latest
- i386: ghcr.io/home-assistant/i386-base:latest
Use docker from the directory containing the add-on files to build the test addon:
docker build \
  --build-arg BUILD_FROM="ghcr.io/home-assistant/amd64-base:latest" \
  -t local/my-test-addon \
Local run
If you don't want to use the devcontainer environment, you can still run add-ons locally with Docker.
For that you can use the following command:
docker run \
  --rm \
  -v /tmp/my_test_data:/data \
  -p PORT_STUFF_IF_NEEDED \
  local/my-test-addon
Logs
All stdout and stderr outputs are redirected to the Docker logs. The logs can be fetched from the add-on page inside the Supervisor panel in Home Assistant.
