Custom Component Localization
Translation Strings
Unlike localized strings merged in the home-assistant repository, custom components cannot take advantage of Lokalise for user submitted translations. However, custom component authors can still include translations with their components. These will be read from the .translations directory, adjacent to the component source. They are named <platform name>.<language_code>.json, e.g., for the German translation of a sensor sensor.de.json, unless the translation is for the custom component only, in which case the file is simply named <language_code>.json in the .translations directory.
These files follow the same formatting as backend translation string files, but a copy will exist for each translated language.
The language codes follow the BCP47 format. The frontend translation files can also be referred to if you are unsure of the correct language code to use.
The frontend will serve these files after Home Assistant is restarted.
