Introducing Integrations
· 2 min read
We have finished the great migration. The result will be released as part of Home Assistant 0.92. The release has been a bit delayed because we had a lot of things to fix! With the migration done, we now consider components and platforms that share the same name to be part of the same integration. Each integration is either a single Python file, or a folder with an __init__.py. file. We have updated the documentation and introduced a new section for integrations.
Home Assistant 0.92 introduces a new manifest.json for integrations. This file, which is optional for custom components, is used by integrations to specify metadata: name, link to the documentation, dependencies, requirements and code owners. We are exploring leveraging manifest.json for additional future features, like tracking breaking changes or allowing custom components to provide config flows and being discovered.
With all these changes, we had to drop a few deprecated things and change some behavior:
  • Platforms can no longer be in the directory of the entity component, like light/my_platform.py. Instead, create a new my_platform folder in your custom_components, create an empty __init__.py file and move light/my_platform.py to my_platform/light.py.
  • Platforms can no longer have dependencies or requirements. Instead, create a manifest.json in the my_platform folder to specify them, or add REQUIREMENTS or DEPENDENCIES constants to the __init__.py file.
  • A platform will now always require the component, if available, to be set up first.
  • It is no longer possible to provide translations for components that are contained in a single Python file. Convert them to an integration in a directory.
  • If you want to override a built-in integration, you need to specify a manifest.json for your custom integration. Note that we strongly discourage overriding built-in integrations. Instead, if you want to run an integration with custom changes change the integration name. For example if you want to run a custom version of the MQTT integration, named mqtt in Home Assistant:
    • Copy the content of the mqtt folder from the Home Assistant repository to a new folder <config>/custom_components/mqtt_custom/
    • Open mqtt_custom/manifest.json and change the value for domain from mqtt to mqtt_custom
    • Open mqtt_custom/__init__.py and change the value of DOMAIN from mqtt to mqtt_custom
    • Anywhere in your config where you referenced mqtt, reference mqtt_custom. So use mqtt_custom: to specify the host and use platform: mqtt_custom when specifying platforms.
