Integration manifest
Every integration has a manifest file to specify its basic information. This file is stored as manifest.json in your integration directory. It is required to add such a file.
"domain": "hue",
"name": "Philips Hue",
"after_dependencies": ["http"],
"codeowners": ["@balloob"],
"dependencies": ["mqtt"],
"documentation": "https://www.home-assistant.io/components/hue",
"integration_type": "hub",
"iot_class": "local_polling",
"issue_tracker": "https://github.com/balloob/hue/issues",
"loggers": ["aiohue"],
"requirements": ["aiohue==1.9.1"],
"quality_scale": "platinum"
Or a minimal example that you can copy into your project:
"domain": "your_domain_name",
"name": "Your Integration",
"codeowners": [],
"dependencies": [],
"documentation": "https://www.example.com",
"iot_class": "cloud_polling",
"requirements": []
Domain
The domain is a short name consisting of characters and underscores. This domain has to be unique and cannot be changed. Example of the domain for the mobile app integration: mobile_app. The domain key has to match the directory this file is in.
Name
The name of the integration must follow these rules:
  • If a product or service offers both local and cloud integrations, the cloud variant should append "Cloud" to the name (for example, LIFX Cloud).
  • The local variant (or one that supports both local and cloud communication) should use the plain product or service name with no suffix (for example, LIFX). Do not append "Local".
  • Integrations for inherently cloud-based products or services should use the name as-is, without any suffix (for example, iCloud not iCloud Cloud).
Version
For core integrations, this should be omitted.
The version of the integration is required for custom integrations. The version needs to be a valid version recognized by AwesomeVersion like CalVer or SemVer.
Integration type
Integrations are split into multiple integration types. Each integration must provide an integration_type in their manifest, that describes its main focus.
warning
Setting an integration_type is required for core integrations with a config flow. For custom and YAML-based integrations, if the integration_type is not set, it will default to hub, but it is recommended to set the correct type explicitly.
TypeDescription
deviceProvides a single device like, for example, ESPHome.
entityProvides a basic entity platform, like sensor or light. This should generally not be used.
hardwareProvides a hardware integration, like Raspberry Pi or Hardkernel. This should generally not be used.
helperProvides an entity to help the user with automations like input boolean, derivative or group.
hubProvides a hub integration, with multiple devices or services, like Philips Hue.
serviceProvides a single service, like DuckDNS or AdGuard.
systemProvides a system integration and is reserved, should generally not be used.
virtualNot an integration on its own. Instead it points towards another integration or IoT standard. See virtual integration section.
info
The difference between a hub and a service or device is defined by the nature of the integration. A hub provides a gateway to multiple other devices or services. service and device are integrations that provide a single device or service per config entry.
Documentation
The website containing documentation on how to use your integration. If this integration is being submitted for inclusion in Home Assistant, it should be https://www.home-assistant.io/integrations/<domain>
Issue tracker
The issue tracker of your integration, where users reports issues if they run into one. If this integration is being submitted for inclusion in Home Assistant, it should be omitted. For built-in integrations, Home Assistant will automatically generate the correct link.
Dependencies
Dependencies are other Home Assistant integrations you want Home Assistant to set up successfully before the integration is loaded. Adding an integration to dependencies will ensure the depending integration is loaded before setup, but it does not guarantee all dependency configuration entries have been set up. Adding dependencies can be necessary if you want to offer functionality from that other integration, like webhooks or an MQTT connection. Adding an after dependency might be a better alternative if a dependency is optional but not critical. See the MQTT section for more details on handling this for MQTT.
Built-in integrations shall only specify other built-in integrations in dependencies. Custom integrations may specify both built-in and custom integrations in dependencies.
After dependencies
This option is used to specify dependencies that might be used by the integration but aren't essential. When after_dependencies is present, set up of an integration will wait for the integrations listed in after_dependencies, which are configured either via YAML or a config entry, to be set up first before the integration is set up. It will also make sure that the requirements of after_dependencies are installed so methods from the integration can be safely imported, regardless of whether the integrations listed in after_dependencies are configured or not. For example, if the camera integration might use the stream integration in certain configurations, adding stream to after_dependencies of camera's manifest, will ensure that stream is loaded before camera if it is configured and that any dependencies of stream are installed and can be imported by camera. If stream is not configured, camera will still load.
Built-in integrations shall only specify other built-in integrations in after_dependencies. Custom integrations may specify both built-in and custom integrations in after_dependencies.
Code owners
GitHub usernames or team names of people that are responsible for this integration. You should add at least your GitHub username here, as well as anyone who helped you to write code that is being included.
Config flow
Specify the config_flow key if your integration has a config flow to create a config entry. When specified, the file config_flow.py needs to exist in your integration.
"config_flow": true
Single config entry only
Specify the single_config_entry key if your integration supports only one config entry. When specified, it will not allow the user to add more than one config entry for this integration.
"single_config_entry": true
Requirements
Requirements are Python libraries or modules that you would normally install using pip for your component. Home Assistant will try to install the requirements into the deps subdirectory of the Home Assistant configuration directory if you are not using a venv or in something like path/to/venv/lib/python3.6/site-packages if you are running in a virtual environment. This will make sure that all requirements are present at startup. If steps fail, like missing packages for the compilation of a module or other install errors, the component will fail to load.
Requirements is an array of strings. Each entry is a pip compatible string. For example, the media player Cast platform depends on the Python package PyChromecast v3.2.0: ["pychromecast==3.2.0"].
Custom requirements during development & testing
During the development of a component, it can be useful to test against different versions of a requirement. This can be done in two steps, using pychromecast as an example:
pip install pychromecast==3.2.0 --target ~/.homeassistant/deps
hass --skip-pip-packages pychromecast
This will use the specified version, and prevent Home Assistant from trying to override it with what is specified in requirements. To prevent any package from being automatically overridden without specifying dependencies, you can launch Home Assistant with the global --skip-pip flag.
If you need to make changes to a requirement to support your component, it's also possible to install a development version of the requirement using pip install -e:
git clone https://github.com/balloob/pychromecast.git
pip install -e ./pychromecast
It is also possible to use a public git repository to install a requirement. This can be useful, for example, to test changes to a requirement dependency before it's been published to PyPI. Syntax:
"requirements": ["<library>@git+https://github.com/<user>/<project>.git@<git ref>"]
<git ref> can be any git reference: branch, tag, commit hash, ... . See PIP documentation about git support.
The following example will install the except_connect branch of the pycoolmaster library directly from GitHub:
"requirements": ["pycoolmaster@git+https://github.com/issacg/pycoolmaster.git@except_connect"]
Custom integration requirements
Custom integrations should only include requirements that are not required by the Core requirements.txt.
Loggers
The loggers field is a list of names that the integration's requirements use for their getLogger calls.
Bluetooth
If your integration supports discovery via bluetooth, you can add a matcher to your manifest. If the user has the bluetooth integration loaded, it will load the bluetooth step of your integration's config flow when it is discovered. We support listening for Bluetooth discovery by matching on connectable local_name, service_uuid, service_data_uuid, manufacturer_id, and manufacturer_data_start. The manufacturer_data_start field expects a list of bytes encoded as integer values from 0-255. The manifest value is a list of matcher dictionaries. Your integration is discovered if all items of any of the specified matchers are found in the Bluetooth data. It's up to your config flow to filter out duplicates.
Matches for local_name may not contain any patterns in the first three (3) characters.
If the device only needs advertisement data, setting connectable to false will opt-in to receive discovery from Bluetooth controllers that do not have support for making connections.
The following example will match Nespresso Prodigio machines:
"bluetooth": [
"local_name": "Prodigio_*"
The following example will match service data with a 128 bit uuid used for SwitchBot bot and curtain devices:
"bluetooth": [
"service_uuid": "cba20d00-224d-11e6-9fb8-0002a5d5c51b"
If you want to match service data with a 16 bit uuid, you will have to convert it to a 128 bit uuid first, by replacing the 3rd and 4th byte in 00000000-0000-1000-8000-00805f9b34fb with the 16 bit uuid. For example, for Switchbot sensor devices, the 16 bit uuid is 0xfd3d, the corresponding 128 bit uuid becomes 0000fd3d-0000-1000-8000-00805f9b34fb. The following example will therefore match service data with a 16 bit uuid used for SwitchBot sensor devices:
"bluetooth": [
"service_data_uuid": "0000fd3d-0000-1000-8000-00805f9b34fb"
The following example will match HomeKit devices:
"bluetooth": [
"manufacturer_id": 76,
"manufacturer_data_start": [6]
Zeroconf
If your integration supports discovery via Zeroconf, you can add the type to your manifest. If the user has the zeroconf integration loaded, it will load the zeroconf step of your integration's config flow when it is discovered.
Zeroconf is a list so you can specify multiple types to match on.
"zeroconf": ["_googlecast._tcp.local."]
Certain zeroconf types are very generic (that is, _printer._tcp.local., _axis-video._tcp.local. or _http._tcp.local). In such cases you should include a Name (name), or Properties (properties) filter:
"zeroconf": [
{"type":"_axis-video._tcp.local.","properties":{"macaddress":"00408c*"}},
{"type":"_axis-video._tcp.local.","name":"example*"},
{"type":"_airplay._tcp.local.","properties":{"am":"audioaccessory*"}},
Note that all values in the properties filters must be lowercase, and may contain a fnmatch type wildcard.
SSDP
If your integration supports discovery via SSDP, you can add the type to your manifest. If the user has the ssdp integration loaded, it will load the ssdp step of your integration's config flow when it is discovered. We support SSDP discovery by the SSDP ST, USN, EXT, and Server headers (header names in lowercase), as well as data in UPnP device description. The manifest value is a list of matcher dictionaries, your integration is discovered if all items of any of the specified matchers are found in the SSDP/UPnP data. It's up to your config flow to filter out duplicates.
The following example has one matcher consisting of three items, all of which must match for discovery to happen by this config.
"ssdp": [
"st": "roku:ecp",
"manufacturer": "Roku",
"deviceType": "urn:roku-com:device:player:1-0"
HomeKit
If your integration supports discovery via HomeKit, you can add the supported model names to your manifest. If the user has the zeroconf integration loaded, it will load the homekit step of your integration's config flow when it is discovered.
HomeKit discovery works by testing if the discovered modelname starts with any of the model names specified in the manifest.json.
"homekit": {
"models": [
"LIFX"
Discovery via HomeKit does not mean that you have to talk the HomeKit protocol to communicate with your device. You can communicate with the device however you see fit.
When a discovery info is routed to your integration because of this entry in your manifest, the discovery info is no longer routed to integrations that listen to the HomeKit zeroconf type.
MQTT
If your integration supports discovery via MQTT, you can add the topics used for discovery. If the user has the mqtt integration loaded, it will load the mqtt step of your integration's config flow when it is discovered.
MQTT discovery works by subscribing to MQTT topics specified in the manifest.json.
"mqtt": [
"tasmota/discovery/#"
If your integration requires mqtt, make sure it is added to the dependencies.
Integrations depending on MQTT should wait using await mqtt.async_wait_for_mqtt_client(hass) for the MQTT client to become available before they can subscribe. The async_wait_for_mqtt_client method will block and return True till the MQTT client is available.
DHCP
If your integration supports discovery via DHCP, you can add the type to your manifest. If the user has the dhcp integration loaded, it will load the dhcp step of your integration's config flow when it is discovered. We support passively listening for DHCP discovery by the hostname and OUI, or matching device registry mac address when registered_devices is set to true. The manifest value is a list of matcher dictionaries, your integration is discovered if all items of any of the specified matchers are found in the DHCP data. Unix filename pattern matching is used for matching. It's up to your config flow to filter out duplicates.
If an integration wants to receive discovery flows to update the IP Address of a device when it comes online, but a hostname or oui match would be too broad, and it has registered in the device registry with mac address using the CONNECTION_NETWORK_MAC, it should add a DHCP entry with registered_devices set to true.
If the integration supports zeroconf or ssdp, these should be preferred over dhcp as it generally offers a better user experience.
The following example has two matchers consisting of two items. All of the items in any of the matchers must match for discovery to happen by this config.
For example:
  • If the hostname was Rachio-XYZ and the macaddress was 00:9D:6B:55:12:AA, the discovery would happen (1st matcher).
  • If the hostname was Dachio-XYZ or Pachio-XYZ, and the macaddress was 00:9D:6B:55:12:AA, the discovery would happen (3rd matcher).
  • If the hostname was Rachio-XYZ and the macaddress was 00:00:00:55:12:AA, the discovery would not happen (no matching MAC).
  • If the hostname was NotRachio-XYZ and the macaddress was 00:9D:6B:55:12:AA, the discovery would not happen (no matching hostname).
"dhcp": [
"hostname": "rachio-*",
"macaddress": "009D6B*"
"hostname": "[dp]achio-*",
Example with setting registered_devices to true:
"dhcp": [
"hostname": "myintegration-*",
"registered_devices": true,
USB
If your integration supports discovery via usb, you can add the type to your manifest. If the user has the usb integration loaded, it will load the usb step of your integration's config flow when it is discovered. We support discovery by VID (Vendor ID), PID (Device ID), Serial Number, Manufacturer, and Description by extracting these values from the USB descriptor. For help identifying these values see How To Identify A Device. The manifest value is a list of matcher dictionaries. Your integration is discovered if all items of any of the specified matchers are found in the USB data. It's up to your config flow to filter out duplicates.
warning
Some VID and PID combinations are used by many unrelated devices. For example VID 10C4 and PID EA60 matches any Silicon Labs CP2102 USB-Serial bridge chip. When matching these type of devices, it is important to match on description or another identifier to avoid an unexpected discovery.
The following example has two matchers consisting of two items. All of the items in any of the two matchers must match for discovery to happen by this config.
For example:
  • If the vid was AAAA and the pid was AAAA, the discovery would happen.
  • If the vid was AAAA and the pid was FFFF, the discovery would not happen.
  • If the vid was CCCC and the pid was AAAA, the discovery would not happen.
  • If the vid was 1234, the pid was ABCD, the serial_number was 12345678, the manufacturer was Midway USB, and the description was Version 12 Zigbee Stick, the discovery would happen.
"usb": [
"vid": "AAAA",
"pid": "AAAA"
"vid": "BBBB",
"pid": "BBBB"
"vid": "1234",
"pid": "ABCD",
"serial_number": "1234*",
"manufacturer": "*midway*",
"description": "*zigbee*"
Integration quality scale
The Integration Quality Scale scores an integration on the code quality and user experience. Each level of the quality scale consists of a list of requirements. If an integration matches all requirements, it's considered to have reached that level.
New integrations are required to fulfill at least the bronze tier so be sure to look at the Integration Quality Scale list of requirements. It helps to improve the code and user experience tremendously.
"quality_scale": "silver"
IoT class
The IoT class describes how an integration connects with, for example, a device or service. For more information about IoT Classes, read the blog about "Classifying the Internet of Things".
The following IoT classes are accepted in the manifest:
  • assumed_state: We are unable to get the state of the device. Best we can do is to assume the state based on our last command.
  • cloud_polling: The integration of this device happens via the cloud and requires an active internet connection. Polling the state means that an update might be noticed later.
  • cloud_push: Integration of this device happens via the cloud and requires an active internet connection. Home Assistant will be notified as soon as a new state is available.
  • local_polling: Offers direct communication with device. Polling the state means that an update might be noticed later.
  • local_push: Offers direct communication with device. Home Assistant will be notified as soon as a new state is available.
  • calculated: The integration does not handle communication on its own, but provides a calculated result.
Virtual integration
Some products are supported by integrations that are not named after the product. For example, Yale Home locks are integrated via the August integration, and the IKEA SYMFONISK product line can be used with the Sonos integration.
There are also cases where a product line only supports a standard IoT standards like Zigbee or Z-Wave. For example, the U-tec ultraloq works via Z-Wave and has no specific dedicated integration.
For end-users, it can be confusing to find how to integrate those products with Home Asssistant. To help with these above cases, Home Assistant has "Virtual integrations". These integrations are not real integrations but are used to help users find the right integration for their device.
A virtual integration is an integration that just has a single manifest file, without any additional code. There are two types of virtual integrations: A virtual integration supported by another integration and one that uses an existing IoT standard.
info
Virtual integrations can only be provided by Home Assistant Core and not by custom integrations.
Supported by
The "Supported by" virtual integration is an integration that points to another integration to provide its implementation. For example, Yale Home locks are integrated via the August (august) integration.
Example manifest:
"domain": "yale_home",
"name": "Yale Home",
"integration_type": "virtual",
"supported_by": "august"
The domain and name are the same as with any other integration, but the integration_type is set to virtual. The logo for the domain of this virtual integration must be added to our brands repository, so in this case, a Yale Home branding is used.
The supported_by is the domain of the integration providing the implementation for this product. In the example above, the Yale Home lock is supported by the August integration and points to its domain august.
Result:
  • Yale Home is listed on our user documentation website under integrations with an automatically generated stub page that directs the user to the integration to use.
  • Yale Home is listed in Home Assistant when clicking "add integration". When selected, we explain to the user that this product is integrated using a different integration, then the user continues to the Xioami Miio config flow.
IoT standards
The "IoT Standards" virtual integration is an integration that uses an existing IoT standard to provide connectivity with the device. For example, the U-tec ultraloq works via Z-Wave and has no specific dedicated integration.
Example manifest:
"domain": "ultraloq",
"name": "ultraloq",
"iot_standards": ["zwave"],
The domain and name are the same as with any other integration, but the integration_type is set to virtual. The logo for the domain of this virtual integration should be added to our brands repository.
The iot_standards is the standard this product uses for connectivity. In the example above, the U-tech ultraloq products use Z-Wave to integrate with Home Assistant.
Result:
  • U-tech ultraloq is listed on our user documentation website under integrations with an automatically generated stub page that directs the user to the integration to use.
  • U-tech ultraloq is listed in Home Assistant when clicking "add integration". When selected, we guide the user in adding this Z-Wave device (and in case Z-Wave isn't set up yet, into setting up Z-Wave first).
info
Brands also support setting IoT standards.
It is preferred to set IoT standards on the brand level, and only use a virtual integration in case it would impose confusion for the end user.
