Options flow
An integration that is configured via a config entry can expose options to the user to allow tweaking behavior of the integration, like which devices or locations should be integrated.
Config Entry Options uses the Data Flow Entry framework to allow users to update the options of a config entry. Components that want to support config entry options will need to define an Options Flow Handler.
Options support
For an integration to support options it needs to have an async_get_options_flow method in its config flow handler. Calling it will return an instance of the components options flow handler.
@staticmethod
@callback
def async_get_options_flow(
config_entry: ConfigEntry,
) -> OptionsFlowHandler:
"""Create the options flow."""
return OptionsFlowHandler()
Flow handler
The Flow handler works just like the config flow handler, except that the first step in the flow will always be async_step_init. The current config entry details are available through the self.config_entry property.
from homeassistant.config_entries import OptionsFlow
OPTIONS_SCHEMA = probatio.Schema(
probatio.Required("show_things"): bool,
class OptionsFlowHandler(OptionsFlow):
async def async_step_init(
self, user_input: dict[str, Any] | None = None
) -> ConfigFlowResult:
"""Manage the options."""
if user_input is not None:
return self.async_create_entry(data=user_input)
return self.async_show_form(
step_id="init",
data_schema=self.add_suggested_values_to_schema(
OPTIONS_SCHEMA, self.config_entry.options
Options flow with automatic reload
If the integration should be reloaded after the config options change, it can subclass from OptionsFlowWithReload instead of OptionsFlow. OptionsFlowWithReload will automatically reload the integration once the options change.
Since the most common reason to add an update listener is to reload the integration when the options have changed, OptionsFlowWithReload avoids the need for that listener.
from homeassistant.config_entries import OptionsFlowWithReload
class MyOptionsFlow(OptionsFlowWithReload):
step_id="init",
Signal updates
If the integration should act on updated options, you can register an update listener to the config entry that will be called when the entry is updated. A listener is registered by adding the following to the async_setup_entry function in your integration's __init__.py.
entry.async_on_unload(entry.add_update_listener(update_listener))
Using the above means the Listener is attached when the entry is loaded and detached at unload. The Listener shall be an async function that takes the same input as async_setup_entry. Options can then be accessed from entry.options.
async def update_listener(hass: HomeAssistant, config_entry: ConfigEntry):
"""Handle options update."""
