Creating your first integration
Alright, so it's time to write your first code for your integration. AWESOME. Don't worry, we've tried hard to keep it as easy as possible. From a Home Assistant development environment, type the following and follow the instructions:
python3 -m script.scaffold integration
This will set you up with everything that you need to build an integration that is able to be set up via the user interface. More extensive examples of integrations are available from our example repository.
tip
This example repository shows custom integrations that live in the <config_dir>/custom_components directory. These MUST have a version key in their manifest file. Core integrations live in the homeassistant/components directory, and do not need a version key. The architecture is the same in both cases.
The minimum​
The scaffold integration contains a bit more than just the bare minimum. The minimum is that you define a DOMAIN constant that contains the domain of the integration. The second part is that it needs to define a setup method that returns a boolean if the set-up was successful.
Create a file homeassistant/components/hello_state/__init__.py with one of the two following codeblocks, depending on what you need:
  • Sync component:
from homeassistant.helpers.typing import ConfigType
DOMAIN = "hello_state"
def setup(hass: HomeAssistant, config: ConfigType) -> bool:
hass.states.set("hello_state.world", "Paulus")
# Return boolean to indicate that initialization was successful.
return True
  • And if you prefer an async component:
async def async_setup(hass: HomeAssistant, config: ConfigType) -> bool:
hass.states.async_set("hello_state.world", "Paulus")
return True
In addition, a manifest file is required with the following keys as the bare minimum. Create homeassistant/components/hello_state/manifest.json.
"domain": "hello_state",
"name": "Hello, state!"
To load this, add hello_state: to your configuration.yaml file.
What the scaffold offers​
When using the scaffold script, it will go past the bare minimum of an integration. It will include a config flow, tests for the config flow and basic translation infrastructure to provide internationalization for your config flow.
