Integration service actions
Home Assistant provides ready-made actions for a lot of things, but it doesn't always cover everything. Instead of trying to change Home Assistant, it is preferred to add it as a service action under your own integration first. Once we see a pattern in these service actions, we can talk about generalizing them.
Service actions should always be registered to ensure automations referencing them can be edited and validated, and to allow an informative error message when a service is called even if the integration has no loaded config entries. Register services in the integration's async_setup or setup function, not in the integration's async_setup_entry or in a platform's async_setup_entry, async_setup_platform, or setup_platform.
This is a simple "hello world" example to show the basics of registering a service action. To use this example, create the file <config dir>/custom_components/hello_action/__init__.py and copy the below example code.
Actions can be called from automations and from the Actions tab of Tools in the frontend.
from homeassistant.core import HomeAssistant, ServiceCall, callback
from homeassistant.helpers.typing import ConfigType
DOMAIN = "hello_action"
ATTR_NAME = "name"
DEFAULT_NAME = "World"
async def async_setup(hass: HomeAssistant, config: ConfigType) -> bool:
"""Set up is called when Home Assistant is loading our component."""
@callback
def handle_hello(call: ServiceCall) -> None:
"""Handle the service action call."""
name = call.data.get(ATTR_NAME, DEFAULT_NAME)
hass.states.async_set("hello_action.hello", name)
hass.services.async_register(DOMAIN, "hello", handle_hello)
# Return boolean to indicate that initialization was successful.
return True
To load the integration in Home Assistant is necessary to create a manifest.json and to add an entry in your configuration.yaml. When your component is loaded, a new service should be available to call.
# configuration.yaml entry
hello_action:
An example of manifest.json:
"domain": "hello_action",
"name": "Hello Action",
"documentation": "https://developers.home-assistant.io/docs/dev_101_services",
"iot_class": "local_push",
"version": "0.1.0"
Open the frontend and in the sidebar, click the first icon in the developer tool section. This will open the Actions developer tool. On the right, find your action and click on it. This will automatically fill in the correct values.
Pressing "Perform action" will now call your service action without any parameters. This will cause your service action to create a state with the default name 'World'. If you want to specify the name, you have to specify a parameter by providing it through service action Data. In YAML mode, add the following and press "Perform Service" again.
service: hello_action.hello
The service action will now overwrite the previous state with "Planet".
Service action descriptions​
Adding actions is only useful if users know about them. In Home Assistant we use a services.yaml as part of your integration to describe the service actions.
Actions are published under the domain name of your integration, so in services.yaml we only use the service action name as the base key.
Service action description example​
# Example services.yaml entry
# Service ID
set_speed:
# If the service action accepts entity IDs, target allows the user to specify
# entities by entity, device, or area. If `target` is specified, `entity_id`
# should not be defined in the `fields` map. By default it shows only targets
# matching entities from the same domain as the action, but if further
# customization is required, target supports the entity, device, and area
# selectors (https://www.home-assistant.io/docs/blueprint/selectors/).
# Entity selector parameters will automatically be applied to device and area,
# and device selector parameters will automatically be applied to area.
entity:
domain: fan
# If not all entities from the action's domain support an action, entities
# can be further filtered by the `supported_features` state attribute. An
# entity will only be possible to select if it supports at least one of the
# listed supported features.
supported_features:
- fan.FanEntityFeature.SET_SPEED
# If a service action requires more than one supported feature, the item
# should be given as a list of required supported features. For example,
# if the service action requires both SET_SPEED and OSCILLATE it would
# be expressed like this
- - fan.FanEntityFeature.SET_SPEED
- fan.FanEntityFeature.OSCILLATE
# Different fields that your service action accepts
fields:
# Key of the field
speed:
# Whether or not field is required (default = false)
required: true
# Example value that can be passed for this field
example: "low"
# The default field value
default: "high"
# Selector (https://www.home-assistant.io/docs/blueprint/selectors/) to control
# the input UI for this field
selector:
select:
translation_key: "fan_speed"
options:
- "off"
- "low"
- "medium"
- "high"
# Fields can be grouped in collapsible sections, this is useful to initially hide
# less commonly used fields and to group related fields. Note that the collapsible section
# only affect presentation to the user, service action data will not be nested.
additional_fields:
# Whether or not the section is initially collapsed (default = false)
collapsed: true
# Input fields in this section
fields:
speed_pct:
selector:
number:
min: 0
max: 100
info
The name and description of the service actions are set in our translations and not in the service action description. Each service action and service action field must have a matching translation defined. Description placeholders allow you to exclude elements like URLs from translations.
DOMAIN,
"hello", handle_hello,
description_placeholders={"docs_url": "https://example.com/hello_world"},
Grouping of service action fields​
Input fields can be visually grouped in sections. Grouping input fields by sections influences only how the inputs are displayed to the user, and not how service action data is structured.
In the service action description example, the speed_pct input field is inside an initially collapsed section additional_fields. The service action data for the service in the example is {"speed_pct": 50}, not {"additional_fields": {"speed_pct": 50}}.
Filtering service action fields​
In some cases, entities from an action's domain may not support all service action fields. By providing a filter for the field description, the field will only be shown if at least one selected entity supports the field according to the configured filter.
A filter must specify either supported_features or attribute, combing both is not supported.
A supported_features filter is specified by of a list of supported features. The field will be shown if at least one selected entity supports at least one of the listed features.
An attribute filter combines an attribute with a list of values. The field will be shown if at least one selected entity's attribute is set to one of the listed attribute states. If the attribute state is a list, the field will be shown if at least one item in a selected entity's attribute state is set to one of the listed attribute states.
This is a partial example of a field which is only shown if at least one selected entity supports ClimateEntityFeature.TARGET_TEMPERATURE:
fields:
temperature:
description: New target temperature for HVAC.
filter:
supported_features:
- climate.ClimateEntityFeature.TARGET_TEMPERATURE
This is a partial example of a field which is only shown if at least one selected entity's supported_color_modes attribute includes either light.ColorMode.COLOR_TEMP or light.ColorMode.HS:
color_temp:
name: Color temperature
description: Color temperature for the light in mireds.
filter:
attribute:
supported_color_modes:
- light.ColorMode.COLOR_TEMP
- light.ColorMode.HS
Icons​
Actions can also have icons. These icons are used in the Home Assistant UI when displaying the service action in places like the automation and script editors.
The icon to use for each service action can be defined in the icons.json translation file in the integration folder, under the services key. The key should be the service action name, and the value should be the icon to use.
The following example shows how to provide icons for the turn_on and turn_off service actions of an integration:
"services": {
"turn_on": {"service": "mdi:lightbulb-on"},
"turn_off": {"service": "mdi:lightbulb-off"}
In addition, icons can optionally be specified for collapsible sections.
The following example shows how to provide an icon for the additional_options section:
"services": {
"start_brewing": {
"service": "mdi:flask",
"sections": {
"additional_options": "mdi:test-tube"
Choosing the right target for service actions​
When registering a service action, target it at the level of the data hierarchy that the action actually needs to function. Do not target a higher or lower level than necessary, even if the levels can be resolved to each other.
  • Entity level — If the service action operates on or requires a specific entity to function, use entity_id as the target. For example controlling a light. Register these as entity service actions.
  • Device level — If the service action operates on a device as a whole and requires a device entry (not a specific entity) to function, use a device_id field as the target. Do not use entity_id as a substitute, even if an entity could be resolved to its parent device. For example, an action that reboots a device applies to the device itself, not to any specific entity it exposes, so it should target the device.
  • Config entry level — If the service action operates on the integration instance and requires a config entry to function, use config_entry_id as the target. Do not use a device_id or entity_id as a substitute, even if they could be resolved back to the config entry. For example, an action that creates a new resource, that is common for the whole account or connection, in an external API should target the config entry that represents the account or connection, not a device or entity under it.
tip
The guiding principle is: target the thing the action actually acts on. If the action needs a device, target the device. If it needs a config entry, target the config entry. Resolving from a lower level (for example, looking up a config entry from an entity) adds unnecessary indirection, couples the action interface to assumptions about the data hierarchy in the integration, and makes it harder for users to understand what the action operates on.
caution
When a service action requires a target, this target should not be optional. Do not implement a default target when none is specified.
Making the target optional seems convenient, but it makes automations and scripts unpredictable when the configuration changes by adding entities or entries. Requiring an explicit target keeps action calls predictable regardless of the user's current configuration.
Entity service actions​
Sometimes you want to provide extra actions to control your entities. For example, the Sonos integration provides action to group and ungroup devices. Entity service actions are special because there are many different ways a user can specify entities. It can use areas, a group or a list of entities.
Register entity service actions with homeassistant.helpers.service.async_register_platform_entity_service. Register actions under your integration domain, for example, sonos, not under the platform domain, for example, media_player. You can pass a schema to async_register_platform_entity_service if the entity service action has fields. The schema can be:
  • A dictionary which will automatically be passed to cv._make_entity_service_schema
  • A validator returned by cv._make_entity_service_schema
  • A validator returned by cv._make_entity_service_schema, wrapped in a probatio.Schema
  • A validator returned by cv._make_entity_service_schema, wrapped in a probatio.All
Example code added to homeassistant/components/sonos/__init__.py:
from homeassistant.components.media_player import DOMAIN as MEDIA_PLAYER_DOMAIN
from homeassistant.helpers import config_validation as cv, service
import probatio
DOMAIN = "sonos"
SERVICE_SET_TIMER = "set_sleep_timer"
"""Set up the Sonos integration."""
# This will call each targeted entity's `set_sleep_timer` method with `sleep_time=VALUE`
service.async_register_platform_entity_service(
hass,
DOMAIN,
SERVICE_SET_TIMER,
entity_domain=MEDIA_PLAYER_DOMAIN,
schema={probatio.Required("sleep_time"): cv.time_period},
func="set_sleep_timer",
return True
If you need more control over the service action call, you can also pass an async function that will be called instead of "set_sleep_timer":
async def custom_set_sleep_timer(entity, service_call):
await entity.set_sleep_timer(service_call.data['sleep_time'])
Response data​
Actions may respond to an action call with data for powering more complex automations. There are some additional implementation requirements:
  • Response data must be a dict and serializable in JSON homeassistant.util.json.JsonObjectType in order to interoperate with other parts of the system, such as the frontend.
  • Errors must be raised as exceptions just like any other service action call as we do not want end users to need complex error handling in scripts and automations. The response data should not contain error codes used for error handling.
Example code:
import datetime
import probatio
from homeassistant.config_entries import ConfigEntry
from homeassistant.core import HomeAssistant, ServiceCall, ServiceResponse, SupportsResponse
from homeassistant.helpers import config_validation as cv, entity_platform, service
from homeassistant.util.json import JsonObjectType
SEARCH_ITEMS_SERVICE_NAME = "search_items"
SEARCH_ITEMS_SCHEMA = probatio.Schema({
probatio.Required("start"): datetime.datetime,
probatio.Required("end"): datetime.datetime,
"""Set up the integration."""
async def search_items(call: ServiceCall) -> ServiceResponse:
"""Search in the date range and return the matching items."""
items = await my_client.search(call.data["start"], call.data["end"])
return {
"items": [
"summary": item["summary"],
"description": item["description"],
} for item in items
DOMAIN,
SEARCH_ITEMS_SERVICE_NAME,
search_items,
schema=SEARCH_ITEMS_SCHEMA,
supports_response=SupportsResponse.ONLY,
The use of response data is meant for cases that do not fit the Home Assistant state. For example, a response stream of objects. Conversely, response data should not be used for cases that are a fit for entity state. For example, a temperature value should just be a sensor.
Supporting response data​
Action calls are registered with a SupportsResponse value to indicate response data is supported.
ValueDescription
OPTIONALPerforms an action and can optionally return response data. The service action should conditionally check the ServiceCall property return_response to decide whether or not response data should be returned, or None.
ONLYDoesn't perform any actions and always returns response data.
