Validate the input
The configuration.yaml file contains the configuration options for components and platforms. We use probatio to make sure that the configuration provided by the user is valid. Some entries are optional or could be required to set up a platform or a component. Others must be a defined type or from an already-defined list.
We test the configuration to ensure that users have a great experience and minimize notifications if something is wrong with a platform or component setup before Home Assistant runs.
Besides probatio default types, many custom types are available. For an overview, take a look at the config_validation.py helper.
Some of those helpers are now thin aliases for a probatio validator, and core calls the validator directly:
config_validation helperprobatio validator
cv.ensure_listprobatio.EnsureList()
cv.portprobatio.Port()
cv.has_at_least_one_keyprobatio.AtLeastOne
cv.has_at_most_one_keyprobatio.AtMostOne
The cv names keep working for custom integrations, but a lint rule stops core from using them, so write the probatio form in an integration meant for core.
  • Types: string, byte, and boolean
  • Entity ID: entity_id and entity_ids
  • Numbers: small_float and positive_int
  • Time: time, time_zone
  • Misc: template, slug, temperature_unit, latitude, longitude, isfile, sun_event, url, and icon
To validate platforms using MQTT, valid_subscribe_topic and valid_publish_topic are available.
Some things to keep in mind:
  • Use the constants defined in const.py
  • Import PLATFORM_SCHEMA from the integration you are integrating with and extend it.
  • Preferred order is required first and optional second
  • Default values for optional configuration keys need to be valid values. Don't use a default which is None like probatio.Optional(CONF_SOMETHING, default=None): cv.string, set the default to default='' if required.
Snippets​
This section contains snippets for the validation we use.
Default name​
It's common to set a default for a sensor if the user doesn't provide a name to use.
DEFAULT_NAME = "Sensor name"
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
probatio.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
Limit the values​
You might want to limit the user's input to a couple of options.
DEFAULT_METHOD = "GET"
probatio.Optional(CONF_METHOD, default=DEFAULT_METHOD): probatio.In(
["POST", "GET"]
Port​
All port numbers are from a range of 1 to 65535.
DEFAULT_PORT = 993
probatio.Optional(CONF_PORT, default=DEFAULT_PORT): probatio.Port(),
Secrets​
When a key holds a credential, wrap it in probatio.Secret. A validation failure then reports the path and the reason without the value, so a password does not end up in the log.
probatio.Required(CONF_HOST): cv.string,
probatio.Required(probatio.Secret(CONF_PASSWORD)): cv.string,
A password that fails validation now reads:
Invalid config for 'demo': value should be a string for dictionary value 'password', got **REDACTED**
Mark a key whose value grants access, such as a password, a token, an API key or a PIN that authenticates. Do not mark a key that merely identifies something. A host, a serial number or a GPIO pin number is not a secret, and redacting it makes the error useless to the person trying to fix their configuration.
Lists​
If a sensor has a pre-defined list of available options, test to make sure the configuration entry matches the list.
SENSOR_TYPES = {
"article_cache": ("Article Cache", "MB"),
"average_download_rate": ("Average Speed", "MB/s"),
probatio.Optional(CONF_MONITORED_VARIABLES, default=[]): probatio.All(
probatio.EnsureList(), [probatio.In(SENSOR_TYPES)]
