Conversation API
Intents can be recognized from text and fired using the conversation integration.
An API endpoint is available which receives an input sentence and produces a conversation response. A "conversation" is tracked across multiple inputs and responses by passing a conversation id generated by Home Assistant.
The API is available via the Rest API and Websocket API.
A sentence may be POST-ed to /api/conversation/process like:
"text": "turn on the lights in the living room",
"language": "en"
Or sent via the WebSocket API like:
"type": "conversation/process",
"language": "en"
The following input fields are available:
| Name | Type | Description |
text | string | Input sentence. |
language | string | Optional. Language of the input sentence (defaults to configured language). |
agent_id | string | Optional. Conversation agent to process the request (defaults home_assistant). |
conversation_id | string | Optional. Unique id to track conversation. Generated by Home Assistant. |
Conversation response
The JSON response from /api/conversation/process contains information about the effect of the fired intent, for example:
"continue_conversation": true,
"response": {
"response_type": "action_done",
"language": "en",
"data": {
"success": [
"name": "Living Room",
"type": "area",
"id": "living_room"
"name": "My Light",
"type": "entity",
"id": "light.my_light"
"failed": []
"speech": {
"plain": {
"speech": "Turned Living Room lights on"
"conversation_id": "<generated-id-from-ha>",
The following properties are available in the "response" object:
response_type | string | One of action_done, query_answer, or error (see response types). |
data | dictionary | Relevant data for each response type. |
language | string | The language of the intent and response. |
speech | dictionary | Optional. Response text to speak to the user (see speech). |
The conversation id is returned alongside the conversation response.
If continue_conversation is set to true, the conversation agent expects a follow-up from the user.
Response types
Action done
The intent produced an action in Home Assistant, such as turning on a light. The data property of the response contains a success list and a failed list. Each entry in these lists is a target that was acted on, and looks like:
name | string | Name of the affected target. |
type | string | Target type. One of area, floor, domain, device_class, device, entity, or custom. |
id | string | Optional. Id of the target. |
The success list contains the targets (such as areas, floors, and entities/devices) that were acted on successfully, and the failed list contains those that failed:
"response": {
"data": {
"success": [
(targets that succeeded)
"failed": [
(targets that failed)
An intent can have multiple targets which are applied on top of each other. The targets must be ordered from general to specific:
floor- A registered floor, which groups multiple areas
areadomain- Home Assistant integration domain, such as "light"
device_class- Device class for a domain, such as "garage_door" for the "cover" domain
deviceentitycustom- A custom target
Most intents end up with 0, 1 or 2 targets. 3 targets currently only happens when device classes are involved. Examples of target combinations:
- "Turn off all lights"
- 1 target:
domain:light
- 1 target:
- "Turn on the kitchen lights"
- 2 targets:
area:kitchen,domain:light
- 2 targets:
- "Open the kitchen blinds"
- 3 targets:
area:kitchen,domain:cover,device_class:blind
- 3 targets:
Query answer
The response is an answer to a question, such as "what is the temperature?". See the speech property for the answer text.
"response": {
"response_type": "query_answer",
"language": "en",
"speech": {
"plain": {
"speech": "It is 65 degrees"
"data": {
"success": [
"name": "Ecobee",
"type": "entity",
"id": "climate.ecobee"
"failed": []
Error
An error occurred either during intent recognition or handling. See data.code for the specific type of error, and the speech property for the error message.
"response": {
"response_type": "error",
"language": "en",
"data": {
"code": "no_intent_match"
"speech": {
"plain": {
"speech": "Sorry, I didn't understand that"
data.code is a string that can be one of:
no_intent_match- The input text did not match any intents.no_valid_targets- The targeted area, device, or entity does not exist.failed_to_handle- An unexpected error occurred while handling the intent.unknown- An error occurred outside the scope of intent processing.
Speech
The spoken response to the user is provided in the speech property of the response. It can either be plain text (the default), or SSML.
For plain text speech, the response will look like:
"response": {
"response_type": "...",
"speech": {
"plain": {
"speech": "...",
"extra_data": null
If the speech is SSML, it will instead be:
"response": {
"speech": {
"ssml": {
"speech": "...",
"extra_data": null
Conversation Id
Conversations can be tracked by a unique id generated from within Home Assistant if supported by the answering conversation agent. To continue a conversation, retrieve the conversation_id from the HTTP API response (alongside the conversation response) and add it to the next input sentence:
Initial input sentence:
"text": "Initial input sentence."
JSON response contains conversation id:
"response": {
(conversation response)
POST with the next input sentence:
"text": "Related input sentence.",
Pre-loading sentences
Sentences for a language can be pre-loaded using the WebSocket API:
"type": "conversation/prepare",
"language": "en"
language | string | Optional. Language of the sentences to load (defaults to configured language). |
