Hass object
While developing Home Assistant you will see a variable that is everywhere: hass. This is the Home Assistant instance that will give you access to all the various parts of the system.
The hass object​
The Home Assistant instance contains four objects to help you interact with the system.
ObjectDescription
hassThis is the instance of Home Assistant. Allows starting, stopping and enqueuing new jobs.
hass.configThis is the core configuration of Home Assistant exposing location, temperature preferences and config directory path.
hass.statesThis is the StateMachine. It allows you to set states and track when they are changed. Learn more.
hass.busThis is the EventBus. It allows you to trigger and listen for events. Learn more.
hass.servicesThis is the ServiceRegistry. It allows you to register service actions. Learn more.
Overview of the Home Assistant core architecture
Where to find hass​
Depending on what you're writing, there are different ways the hass object is made available.
Integration (__init__.py) Passed into async_setup_entry(hass, entry) when a config entry is set up. Integrations that support YAML configuration also get it passed into async_setup(hass, config).
Platform (like light.py) Passed into async_setup_entry(hass, entry, async_add_entities).
Entity Available as self.hass once the entity has been added via the async_add_entities callback in a platform.
