Config
On the hass object there is an instance of the Config class. The Config class contains the users preferred units, the path to the config directory and which components are loaded.
| Name | Type | Description |
| latitude | float | Latitude of the instance location |
| longitude | float | Longitude of the instance location |
| elevation | int | Elevation of the instance |
| location_name | str | Name of the instance |
| time_zone | str | Timezone |
| units | UnitSystem | Unit system |
| internal_url | str | URL the instance can be reached on internally |
| external_url | str | URL the instance can be reached on externally |
| currency | str | Preferred currency |
| country | str | Country the instance is in |
| language | str | Preferred language |
| config_source | ConfigSource | If the configuration was set via the UI or stored in YAML |
| skip_pip | bool | If True, pip install is skipped for requirements on startup |
| skip_pip_packages | list[str] | List of packages to skip when installing requirements on startup |
| components | set[str] | List of loaded components |
| api | ApiConfig | API (HTTP) server configuration |
| config_dir | str | Directory that holds the configuration |
| allowlist_external_dirs | set[str] | List of allowed external dirs to access |
| allowlist_external_urls | set[str] | List of allowed external URLs that integrations may use |
| media_dirs | dict[str, str] | Dictionary of Media folders that integrations may use |
| safe_mode | bool | If Home Assistant is running in safe mode |
| legacy_templates | bool | Use legacy template behavior |
It also provides some helper methods.
