Events
The core of Home Assistant is driven by events. That means that if you want to respond to something happening, you'll have to respond to events. Most of the times you won't interact directly with the event system but use one of the event listener helpers.
The event system is very flexible. There are no limitations on the event type, as long as it's a string. Each event can contain data. The data is a dictionary that can contain any data as long as it's JSON serializable. This means that you can use number, string, dictionary and list.
List of events that Home Assistant fires.
Firing events​
To fire an event, you have to interact with the event bus. The event bus is available on the Home Assistant instance as hass.bus. Please be mindful of the data structure as documented on our Data Science portal.
Example component that will fire an event when loaded. Note that custom event names are prefixed with the component name.
from homeassistant.helpers.typing import ConfigType
DOMAIN = "example_component"
def setup(hass: HomeAssistant, config: ConfigType) -> bool:
"""Set up is called when Home Assistant is loading our component."""
# Fire event example_component_my_cool_event with event data answer=42
hass.bus.fire("example_component_my_cool_event", {"answer": 42})
# Return successful setup
return True
Listening to events​
Most of the times you'll not be firing events but instead listen to events. For example, the state change of an entity is broadcasted as an event.
from homeassistant.core import Event, HomeAssistant
count = 0
# Listener to handle fired events
def handle_event(event: Event) -> None:
nonlocal count
count += 1
print(f"Answer {count} is: {event.data.get('answer')}")
# Listen for when example_component_my_cool_event is fired
hass.bus.listen("example_component_my_cool_event", handle_event)
return True
Helpers​
Home Assistant comes with a lot of bundled helpers to listen to specific types of event. There are helpers to track a point in time, to track a time interval, a state change or the sun set. See available methods.
