Set up development environment
You'll need to set up a development environment if you want to develop a new feature or component for Home Assistant. Read on to learn how to set up.
Developing with Visual Studio Code + devcontainer
Follow our devcontainer development environment guide to set up a proper development environment first.
note
As this approach uses containers, you may face challenges exposing hardware like USB devices & adapters (onboard Bluetooth, Zigbee, ...) into the container for testing. This is possible when developing on a Linux host; however, you cannot directly access such hardware if you are using a Windows or MacOS computer for development.
Getting started:
  1. Go to Home Assistant core repository and click Fork.
  2. Copy your fork's URL and paste it below, then click Open:
  3. Your browser will prompt you if you want to use Visual Studio Code to open the link, click Open Link.
  4. When Visual Studio Code asks if you want to install the Dev Containers extension, click Install.
  5. The dev container image will then be built (this may take a few minutes), after this your development environment will be ready.
  6. You can verify that your dev container is set up properly by the following:
    1. Open the Command Palette in Visual Studio Code:
      • Mac: Shift+Command+P
      • Windows/Linux: Ctrl+Shift+P
    2. Select Tasks: Run Task -> Run Home Assistant Core
    3. A terminal should open and begin outputting activity. Check for errors and wait for the output to stop/slow down.
    4. Navigate a web browser to http://localhost:8123, and you should see the Home Assistant setup screen.
In the future, if you want to get back to your development environment: open Visual Studio Code, click on the Remote Explorer button in the sidebar, select Containers at the top of the sidebar.
  • If your container fails to build due to outdated dependencies or a previously built devcontainer, it might be using a stale fork of your repository. Follow these steps:
    • Ensure your GitHub fork is up-to-date with the main Home Assistant core repository.
    • Clean local Docker build files by running docker buildx prune in the terminal.
    • If the build still fails:
      • Select "Open configuration in recovery devcontainer."
      • Open a terminal (if not already open).
      • Run git pull upstream dev and ensure it applies the current version.
      • Open the command palette in Visual Studio Code - Shift+Command+P (Mac) / Ctrl+Shift+P (Windows/Linux).
      • Select "Dev Containers: Rebuild Container."
Tasks
The dev container comes with some useful tasks to help you with development. You can run these tasks by opening the Command Palette with Shift+Command+P(Mac) / Ctrl+Shift+P (Windows/Linux) and selecting Tasks: Run Task, then finally selecting the task you want to run.
When a task is currently running (like Preview for the docs), it can be restarted by opening the Command Palette and selecting Tasks: Restart Running Task, then select the task you want to restart.
Debugging with Visual Studio Code
If the dev container was set up correctly - it supports debugging by default, out-of-the-box. It provides the necessary debug configurations, so hitting F5 should launch Home Assistant. Any breakpoints put in the code should be triggered, and the debugger should stop.
It is also possible to debug a remote Home Assistant instance (for example, production instance) by following the procedure described here.
Manual Environment
You only need these instructions if you do not want to use devcontainers.
It is also possible to set up a more traditional development environment. See the section below for your operating system. Make sure your Python version is 3.14.2 or higher.
note
If you proceed without the correct Python version installed, you will end up with a virtual environment that is incompatible with Home Assistant. Once you have installed the correct version, remove the venv directory and continue with the setup to recreate it with the correct version.
Developing on Ubuntu / Debian
Install the core dependencies.
sudo apt-get update
sudo apt-get install python3-pip python3-dev python3-venv autoconf libssl-dev libxml2-dev libxslt1-dev libjpeg-dev libffi-dev libudev-dev zlib1g-dev pkg-config libavformat-dev libavcodec-dev libavdevice-dev libavutil-dev libswscale-dev libswresample-dev libavfilter-dev ffmpeg libgammu-dev build-essential
Developing on Fedora
sudo dnf update
sudo dnf install python3-pip python3-devel python3-virtualenv autoconf openssl-devel libxml2-devel libxslt-devel libjpeg-turbo-devel libffi-devel systemd-devel zlib-devel pkgconf-pkg-config libavformat-free-devel libavcodec-free-devel libavdevice-free-devel libavutil-free-devel libswscale-free-devel ffmpeg-free-devel libavfilter-free-devel ffmpeg-free gcc gcc-c++ cmake
Developing on Arch / Manjaro
sudo pacman -Sy base-devel python python-pip python-virtualenv autoconf libxml2 libxslt libjpeg-turbo libffi systemd zlib pkgconf ffmpeg gcc cmake
Developing on NixOS
Drop a default.nix with the contents below in the checked out repository and activate it with, for example, direnv.
let
pkgs = import <nixpkgs> { };
in
pkgs.mkShell {
packages = with pkgs; [
autoconf
clang
cmake
ffmpeg
ffmpeg.dev
gammu
libffi.dev
libjpeg.dev
libxml2.dev
libxslt.dev
openssl_3.dev
pkg-config
python314
zlib.dev
env = {
LD_LIBRARY_PATH = "${pkgs.libjpeg.out}/lib";
Developing on Windows
To develop on Windows, you will need to use the Linux subsystem (WSL). Follow the WSL installation instructions and install Ubuntu from the Windows Store. Once you're able to access Linux, follow the Linux instructions.
When working in WSL make sure to keep all code/repos in the WSL environment to avoid issues with file permissions.
tip
If you find that you cannot open the development instance via http://localhost:8123 when using WSL, instead, within a WSL terminal, find the inet address of the eth0 adaptor by running ip addr show eth0. Then use this address, excluding the CIDR block, to access the development instance, that is, if your inet is listed as 172.20.37.6/20, use http://172.20.37.6:8123.
tip
The default networking mode in WSL is NAT. This has some drawbacks like Home Assistant not being able to discover devices on the network and make it hard to access Home Assistant from the LAN. Alternatively, the networking mode can be set to "Mirrrored", which will make WSL use the same network interfaces as on the host machine (they even have the same IP) and has benefits like Multicast support which enables device discovery with mDNS.
Check out the WSL Mirrored mode networking documentation for details on how to enable it.
Developing on macOS
Install Homebrew, then use that to install the dependencies:
brew install python3 autoconf ffmpeg cmake make
Some Python dependencies of Home Assistant, such as cryptography and orjson, contain extensions written in Rust. If no prebuilt wheel is available for your Python version and platform, pip builds them from source, which requires a Rust toolchain. If the script/setup script below fails because rustc or cargo is missing, install Rust as well:
brew install rust
If you encounter build issues with cryptography when running the script/setup script below, check the cryptography documentation for installation instructions.
Setup Local Repository
Visit the Home Assistant Core repository and click Fork. Once forked, setup your local copy of the source using the commands:
git clone https://github.com/YOUR_GIT_USERNAME/name_of_your_fork
cd name_of_your_fork
git remote add upstream https://github.com/home-assistant/core.git
Install the requirements with a provided script named setup.
script/setup
This will create a virtual environment and install all the necessary requirements. You're now set!
Each time you start a new terminal session, you will need to activate your virtual environment:
source .venv/bin/activate
After that you can run Home Assistant like this:
hass -c config
If you encounter a crash (SIGKILL) while running this command on macOS, it's probably caused by the lack of Bluetooth permissions. You can fix it by adding this permission for your Terminal app (System Preferences -> Security & Privacy -> Bluetooth).
The Home Assistant configuration is stored in the config directory at the root of your repository.
