Style guidelines
Home Assistant enforces quite strict PEP8 style and PEP 257 (Docstring Conventions) compliance on all code submitted.
We use Ruff for code formatting. Every pull request is automatically checked as part of the linting process and we never merge submissions that diverge.
Summary of the most relevant points:
  • Comments should be full sentences and end with a period.
  • Imports should be ordered.
  • Constants and the content of lists and dictionaries should be in alphabetical order.
It is advisable to adjust IDE or editor settings to match those requirements.
Our recommendations
For some cases PEPs don't make a statement. This section covers our recommendations about the code style. Those points were collected from the existing code and based on what contributors and developers were using the most. This is basically a majority decision, thus you may not agree with it. But we would like to encourage you follow those recommendations to keep the code consistent.
File headers
The docstring in the file header should describe what the file is about.
"""Support for MQTT lights."""
Log messages
There is no need to add the platform or component name to the log messages. This will be added automatically. Like syslog messages there shouldn't be any period at the end. A widely used style is shown below but you are free to compose the messages as you like.
_LOGGER.error("No route to device: %s", self._resource)
2017-05-01 14:28:07 ERROR [homeassistant.components.sensor.arest] No route to device: 192.168.0.18
Do not print out API keys, tokens, usernames or passwords (even if they are wrong). Be restrictive with _LOGGER.info, use _LOGGER.debug for anything which is not targeting the user.
Use new style string formatting
Prefer f-strings over % or str.format.
# New
f"{some_value} {some_other_value}"
# Old, wrong
"{} {}".format("New", "style")
"%s %s" % ("Old", "style")
One exception is for logging which uses the percentage formatting. This is to avoid formatting the log message when it is suppressed.
_LOGGER.info("Can't connect to the webservice %s at %s", string1, string2)
Typing
We encourage the use of fully typing your code. This helps with finding/preventing issues and bugs in our codebase, but also helps fellow contributors making adjustments to your code in the future as well.
By default, Home Assistant will statically check for type hints in our automated CI process. Python modules can be included for strict checking, if they are fully typed, by adding an entry to the .strict-typing file in the root of the Home Assistant Core project.
Function docstring convention
Type annotations usually document function parameters.
When you need extended documentation, follow the Google style for docstrings that document parameters, return values, or exceptions. In such cases, type information for the parameters and the return value should already be specified in the type annotations, and should be omitted from the docstrings.
def some_method(self, param1: str, param2: str) -> int:
"""Example Google-style docstring.
Args:
param1: The first parameter.
param2: The second parameter.
Returns:
An integer result.
Raises:
KeyError: If the key doesn't exist.
return 0
