Catching up with reality
If it's taking a while to develop your feature, and you want to catch up with what's in the current Home Assistant dev branch, you can either use git merge or git rebase.
Below you can find instructions on how to do it using git merge. This will pull the latest Home Assistant changes locally, and merge them into your branch by creating a merge commit.
You should have added an additional remote after you clone your fork. If you did not, do it now before proceeding:
git remote add upstream https://github.com/home-assistant/core.git
# Run this from your feature branch
git fetch upstream dev  # to fetch the latest changes into a local dev branch
git merge upstream/dev  # to put those changes into your feature branch before your changes
If git detects any conflicts do the following to solve them:
- Use
git statusto see the file with the conflict; edit the file and resolve the lines between<<<< | >>>> - Add the modified file:
git add <file>orgit add . - Finish the merge by committing it (you can leave the default merge commit message unchanged):
git commit
Finally, just push your changes as normal:
git push
If that command fails, it means that new work was pushed to the branch from either you or another contributor since your last update. In that case, just pull them into your local branch, solve any conflicts and push everything again:
git pull --no-rebase
git push
Other workflows are covered in detail in the Github documentation.
