Testing your code
As stated in the Style guidelines section all code is checked to verify the following:
- All the unit tests pass
- All code passes the checks from the linting tools
Local testing is done using pytest and using prek for running our linters, which has been installed as part of running script/setup in the virtual environment.
Python test requirements need to be installed before tests can be run. This can be achieved by using the VScode devcontainer and the corresponding task. Check the devcontainer documentation for guidance about running tasks.
To run our linters, on the full code base, run the following command:
prek run --all-files
To start the tests, and run the full test suite, activate the virtual environment and run the command:
pytest tests
Or, in Visual Studio Code, launch the Pytest task.
It might be required that you install additional packages depending on your distribution/operating system:
- Fedora:
sudo dnf -y install systemd-devel gcc-c++ - Ubuntu:
sudo apt-get install libudev-dev
Run pytest & prek before you create your pull request to avoid annoying fixes.
prek will be invoked automatically by git when committing changes.
Running the full pytest test suite will take quite some time, so as the minimal requirement for pull requests, run at least the tests that are related to your code changes (see details below on how to). The full test suite will anyway be run by the CI once you created your pull request and before it can be merged.
Running pytest will run unit tests against the locally available Python version. We run our tests in our CI against all our supported Python versions.
Adding new dependencies to test environment
If you are working on tests for an integration and you changed the dependencies, then run the script/gen_requirements_all.py script to update all requirement files.
Next you can update all dependencies in your development environment by running:
uv pip install -r requirements_all.txt -r requirements_test.txt
Or, in Visual Studio Code, launch the Install all (test & production) Requirements task.
Running a limited test suite
You can pass arguments to pytest to be able to run single test suites or test files.
Here are some helpful commands:
# Stop after the first test fails
$ pytest tests/test_core.py -x
# Run test with specified name
$ pytest tests/test_core.py -k test_split_entity_id
# Fail a test after it runs for 2 seconds
$ pytest tests/test_core.py --timeout 2
# Show the 10 slowest tests
$ pytest tests/test_core.py --duration=10
If you want to test just your integration, and include a test coverage report, the following command is recommended:
pytest ./tests/components/<your_component>/ --cov=homeassistant.components.<your_component> --cov-report term-missing -vv
Or, in Visual Studio Code, launch the Code Coverage task.
Preventing linter errors
Several linters are setup to run automatically when you try to commit as part of running script/setup in the virtual environment.
You can also run these linters manually :
prek run --show-diff-on-failure
Or, in Visual Studio Code, launch the Prek task.
The linters are also available directly, you can run tests on individual files:
ruff check homeassistant/core.py
pylint homeassistant/core.py
Notes on PyLint and PEP8 validation
If you can't avoid a PyLint warning, add a comment to disable the PyLint check for that line with # pylint: disable=YOUR-ERROR-NAME. Example of an unavoidable one is if PyLint incorrectly reports that a certain object doesn't have a certain member.
Writing tests for integrations
- Make sure to not interact with any integration details in tests of integrations. Following this pattern will make the tests more robust for changes in the integration.
- Set up the integration with the core interface either
async_setup_componentorhass.config_entries.async_setupif the integration supports config entries. - Assert the entity state via the core state machine
hass.states. - Perform service action calls via the core service registry
hass.services. - Assert
DeviceEntrystate via the device registry. - Assert entity registry
RegistryEntrystate via the entity registry. - Modify a
ConfigEntryvia the config entries interfacehass.config_entries. - Assert the state of a config entry via the
ConfigEntry.stateattribute. - Mock a config entry via the
MockConfigEntryclass intests/common.py
Snapshot testing
Home Assistant supports a testing concept called snapshot testing (also known as approval tests), which are tests that assert values against a stored reference value (the snapshot).
Snapshot tests are different from regular (functional) tests and do not replace functional tests, but they can be very useful for testing larger test outputs. Within Home Assistant they could, for example, be used to:
- Ensure the output of an entity state is and remains as expected.
- Ensure an area, config, device, entity, or issue entry in the registry is and remains as expected.
- Ensure the output of a diagnostic dump is and remains as expected.
- Ensure a FlowResult is and remains as expected.
And many more cases that have large output, like JSON, YAML, or XML results.
The big difference between snapshot tests and regular tests is that the results are captured by running the tests in a special mode that creates the snapshots. Any sequential runs of the tests will then compare the results against the snapshot. If the results are different, the test will fail.
Snapshot testing in Home Assistant is built on top of Syrupy, their documentation can thus be applied when writing Home Assistant tests. This is a snapshot test that asserts the output of an entity state:
# tests/components/example/test_sensor.py
from syrupy.assertion import SnapshotAssertion
async def test_sensor(
hass: HomeAssistant,
snapshot: SnapshotAssertion,
) -> None:
"""Test the sensor state."""
state = hass.states.get("sensor.whatever")
assert state == snapshot
When this test is run for the first time, it will fail, as no snapshot exists.
To create (or update) a snapshot, run the test with
the --snapshot-update flag:
pytest tests/components/example/test_sensor.py --snapshot-update
Or, in Visual Studio Code, launch the Update syrupy snapshots task.
This will create a snapshot file in the tests/components/example/snapshots.
The snapshot file is named after the test file, in this case test_sensor.ambr,
and is human-readable. The snapshot files must be committed to the repository.
When the test is run again (without the update flag), it will compare the results against the stored snapshot and everything should pass.
When the test results change, the test will fail and the snapshot needs to be updated again.
Use snapshot testing with care! As it is very easy to create a snapshot, it can be tempting to assert everything against a snapshot. However, remember, it is not a replacement for functional tests.
As an example, when testing if an entity would go unavailable when the device
returns an error, it is better to assert the specific change you expected:
Assert the state of the entity became unavailable. This functional test is a
better approach than asserting the full state of such an entity using a
snapshot, as it assumes it worked as expected (when taking the snapshot).
