Submit your work
Always base your Pull Requests off of the current dev branch, not master.
Submit your improvements, fixes, and new features to Home Assistant one at a time, using GitHub Pull Requests. Here are the steps:
From your fork's dev branch, create a new branch to hold your changes:
git checkout -b some-feature -
Make your changes, create a new platform, develop a new integration, or fix issues.
Test your changes and check for style violations.
Consider adding tests to ensure that your code works. -
If everything looks good according to these musts, commit your changes:
git add .git commit -m "Add some feature"- Write a meaningful commit message and not only something like
UpdateorFix. - Use a capital letter to start with your commit message and do not finish with a full-stop (period).
- Don't prefix your commit message with
[bla.bla]orplatform:. - Write your commit message using the imperative voice, for example,
Add some featurenotAdds some feature.
Push your committed changes back to your fork on GitHub:
git push origin HEAD -
Follow these steps to create your pull request.
- On GitHub, navigate to the main page of the Home Assistant repository.
- In the "Branch" menu, choose the branch that contains your commits (from your fork).
- To the right of the Branch menu, click New pull request.
- Use the base branch dropdown menu to select the branch you'd like to merge your changes into, then use the compare branch drop-down menu to choose the topic branch you made your changes in. Make sure the Home Assistant branch matches with your forked branch (
dev) else you will propose ALL commits between branches. - Type a title and complete the provided template for your pull request.
- Click Create pull request.
Check for comments and suggestions on your pull request and keep an eye on the CI output.
If this is your first time submitting a pull request, the CI won't run until a maintainer approves running it. Just wait, a maintainer will eventually come by and approve it.
