Built-in intents
The following intents are supported:
  • HassTurnOn, HassTurnOff, HassGetState, HassNevermind, HassRespond, HassBroadcast, HassSetPosition, HassGetCurrentDate, HassGetCurrentTime, HassLightSet, HassClimateSetTemperature, HassClimateGetTemperature, HassShoppingListAddItem, HassShoppingListCompleteItem, HassGetWeather, HassListAddItem, HassListCompleteItem, HassListRemoveItem, HassVacuumStart, HassVacuumReturnToBase, HassVacuumCleanArea, HassMediaPause, HassMediaUnpause, HassMediaNext, HassMediaPrevious, HassSetVolume, HassMediaPlayerMute, HassMediaPlayerUnmute, HassSetVolumeRelative, HassMediaSearchAndPlay, HassStartTimer, HassCancelAllTimers, HassCancelTimer, HassIncreaseTimer, HassDecreaseTimer, HassPauseTimer, HassUnpauseTimer, HassTimerStatus, HassFanSetSpeed, HassLawnMowerStartMowing, HassLawnMowerDock
The following intents are deprecated:
  • HassOpenCover, HassCloseCover, HassToggle, HassHumidifierSetpoint, HassHumidifierMode, HassShoppingListLastItems
Slots
For HassTurnOn and HassTurnOff, the slots are optional.
Possible slot combinations are:
Slot combinationExample
name onlytable light
area onlykitchen
area and nameliving room reading light
area and domainkitchen lights
area and device classbathroom humidity
device class and domaincarbon dioxide sensors
Supported intents
HassTurnOn
Turns on a device or entity
  • name - Name of a device or entity
  • area - Name of an area
  • floor - Name of a floor
  • domain - Domain of devices/entities in an area
  • device_class - Device class of devices/entities in an area
Provided by the homeassistant integration.
HassTurnOff
Turns off a device or entity
HassGetState
Gets or checks the state of an entity
  • state - Name of state to match
HassNevermind
Does nothing. Used to cancel a request
HassRespond
Returns response but takes no action
  • response - Text to respond with
HassBroadcast
Announces a message on other satellites
  • message - Message to broadcast (required)
Provided by the assist_satellite integration.
HassSetPosition
Sets the position of an entity
  • position - Position from 0 to 100 (required)
HassGetCurrentDate
Gets the current date
HassGetCurrentTime
Gets the current time
HassLightSet
Sets the brightness or color of a light
  • domain - Domain of targeted devices
  • brightness - Brightness percentage from 0 to 100
  • color - Name of color
  • temperature - Color temperature from 1000 to 10000 Kelvin
Provided by the light integration.
Sets the desired indoor temperature
  • temperature - Temperature in degrees (required)
Provided by the climate integration.
Gets the actual indoor temperature (not the desired indoor temperature as set by HassClimateSetTemperature)
Adds an item to the shopping list
  • item - Item to add (required)
Provided by the shopping_list integration.
Checks off an item from the shopping list
  • item - Item to check off (required)
HassGetWeather
Gets the current weather
  • name - Name of the weather entity to use
Provided by the weather integration.
HassListAddItem
Adds an item to a todo list
  • name - Name of the list (required)
Provided by the todo integration.
Checks off an item from a todo list
HassListRemoveItem
Removes an item from a todo list
  • item - Item to remove (required)
HassVacuumStart
Starts a vacuum
Provided by the vacuum integration.
Returns a vacuum to base
HassVacuumCleanArea
Sends a vacuum to clean an area
  • area - Name of area to be cleaned (required)
HassMediaPause
Pauses a media player
Provided by the media_player integration.
HassMediaUnpause
Unpauses a media player
HassMediaNext
Skips a media player to the next item
HassMediaPrevious
Skips a media player back to the previous item
HassSetVolume
Sets the volume of a media player
  • volume_level - Volume level from 0 to 100 (required)
HassMediaPlayerMute
Mutes a media player
Unmutes a media player
Increases or decreases the volume of a media player
  • volume_step - up, down, or the percentage to change from -100 to 100 (required)
Searched for a media item and plays it
  • search_query - Media to search for and play (required)
  • media_class - Type of media to search for (album, app, artist, channel, composer, contributing_artist, directory, episode, game, genre, image, movie, music, playlist, podcast, season, track, tv_show, url, video)
HassStartTimer
Starts a timer
  • hours - Number of hours
  • minutes - Number of minutes
  • seconds - Number of seconds
  • name - Name attached to the timer
  • conversation_command - Command to execute when timer finishes
HassCancelAllTimers
Cancels all timers
  • area - Area of the device used to start the timer
HassCancelTimer
Cancels a timer
  • start_hours - Hours the timer was started with
  • start_minutes - Minutes the timer was started with
  • start_seconds - Seconds the timer was started with
  • id - ID of the timer
HassIncreaseTimer
Adds time to a timer
HassDecreaseTimer
Removes time from a timer
HassPauseTimer
Pauses a running timer
HassUnpauseTimer
Resumes a paused timer
HassTimerStatus
Reports status of one or more timers
HassFanSetSpeed
Set the speed of a fan
  • percentage - Speed percentage from 0 to 100 (required)
Provided by the fan integration.
Starts a lawn mower
Provided by the lawn_mower integration.
HassLawnMowerDock
Sends a lawn mower to dock
Deprecated intents
These are old intents that are not supported by template matching sentences and are planned to be removed or replaced.
HassOpenCover
Deprecated; use HassTurnOn instead.
Open a cover.
Slot nameTypeRequiredDescription
namestringYesName of the cover entity to open.
HassCloseCover
Deprecated; use HassTurnOff instead.
Close a cover.
namestringYesName of the cover entity to close.
HassToggle
Toggle the state of an entity.
namestringYesName of the entity to toggle.
Set target humidity.
namestringYesName of the entity to control.
humidityinteger, 0-100YesTarget humidity to set.
HassHumidifierMode
Set humidifier mode if supported by the humidifier.
modestringYesThe mode to switch to.
List the last 5 items on the shopping list.
This intent has no slots.
This page is automatically generated based on the Intents repository.
