Handling intents
Any component can register to handle intents. This allows a single component to handle intents fired from multiple voice assistants.
A component has to register an intent handler for each type that it wants to handle. Intent handlers have to extend homeassistant.helpers.intent.IntentHandler
from homeassistant.helpers import intent
from homeassistant.helpers.typing import ConfigType
DATA_KEY = "example_key"
async def async_setup(hass: HomeAssistant, config: ConfigType) -> bool:
hass.data[DATA_KEY] = 0
intent.async_register(hass, CountInvocationIntent())
return True
class CountInvocationIntent(intent.IntentHandler):
"""Handle CountInvocationIntent intents."""
# Type of intent to handle
intent_type = "CountInvocationIntent"
description = "Count how often it has been called"
# Optional. A validation schema for slots
# slot_schema = {
# 'item': cv.string
async def async_handle(self, intent_obj: intent.Intent) -> intent.IntentResponse:
"""Handle the intent."""
intent_obj.hass.data[DATA_KEY] += 1
count = intent_obj.hass.data[DATA_KEY]
response = intent_obj.create_response()
response.async_set_speech(
f"This intent has been invoked {count} times"
return response
