Handling setup failures
Your integration may not be able to be set up for a variety of reasons. The most common cases are because the device or service is offline or the credentials are no longer valid. Your integration must retry setup so it can recover as soon as reasonably possible when the device or service is back online without the user having to restart Home Assistant.
Handling offline or unavailable devices and services
Integrations using async_setup_entry
Raise the ConfigEntryNotReady exception from async_setup_entry in the integration's __init__.py, and Home Assistant will automatically take care of retrying set up later. To avoid doubt, raising ConfigEntryNotReady in a platform's async_setup_entry is ineffective because it is too late to be caught by the config entry setup.
Example
async def async_setup_entry(hass: HomeAssistant, entry: ConfigEntry) -> bool:
"""Set up the config entry for my device."""
device = MyDevice(entry.data[CONF_HOST])
try:
await device.async_setup()
except (asyncio.TimeoutError, TimeoutException) as ex:
raise ConfigEntryNotReady(f"Timeout while connecting to {device.ipaddr}") from ex
If you are using a DataUpdateCoordinator, calling await coordinator.async_config_entry_first_refresh() will also trigger this exception automatically if the first refresh failed.
If your integration supports discovery, Home Assistant will automatically retry as soon as your device or service gets discovered.
Handling logging of a retry
Pass the error message to ConfigEntryNotReady as the first argument. Home Assistant will log at debug level. The error message will also be propagated to the UI and shown on the integrations page. Suppose you do not set a message when raising ConfigEntryNotReady; in that case, Home Assistant will try to extract the reason from the exception that is the cause of ConfigEntryNotReady if it was propagated from another exception.
The integration should not log any non-debug messages about the retry, and should instead rely on the logic built-in to ConfigEntryNotReady to avoid spamming the logs.
Integrations using async_setup_platform
Raise the PlatformNotReady exception from async_setup_platform, and Home Assistant will automatically take care of retrying set up later.
Example
async def async_setup_platform(
config: ConfigType,
async_add_entities: AddEntitiesCallback,
discovery_info: DiscoveryInfoType | None = None,
) -> None:
"""Set up the platform."""
device = MyDevice(config[CONF_HOST])
try:
except ConnectionError as ex:
raise PlatformNotReady(f"Connection error while connecting to {device.ipaddr}: {ex}") from ex
Pass the error message to PlatformNotReady as the first argument. Home Assistant will log the retry once with a log level of
warning, and subsequent retries will be logged at debug level. Suppose you do not set a message when raising PlatformNotReady; in that case, Home Assistant will try to extract the reason from the exception that is the cause of PlatformNotReady if it was propagated from another exception.
The integration should not log any non-debug messages about the retry, and should instead rely on the logic built-in to PlatformNotReady to avoid spamming the logs.
Handling expired credentials
Raise the ConfigEntryAuthFailed exception, and Home Assistant will automatically put the config entry in a failure state and start a reauth flow. The exception must be raised from async_setup_entry in __init__.py or from the DataUpdateCoordinator or the exception will not be effective at triggering the reauth flow. If your integration does not use a DataUpdateCoordinator, calling entry.async_start_reauth() can be used as an alternative to starting a reauth flow.
The reauth flow will be started with the following context variables, which are available in the async_step_reauth step:
- source: This will always be "SOURCE_REAUTH"
- entry_id: The entry_id of the config entry that needs reauthentication
- unique_id: The unique_id of the config entry that needs reauthentication
Example
try:
except AuthFailed as ex:
raise ConfigEntryAuthFailed(f"Credentials expired for {device.name}") from ex
raise ConfigEntryNotReady(f"Timed out while connecting to {device.ipaddr}") from ex
