Config flow
Integrations can be set up via the user interface by adding support for a config flow to create a config entry. Integrations that want to support config entries will need to define a Config Flow Handler. This handler will manage the creation of entries from user input, discovery or other sources (like Home Assistant OS).
Config Flow Handlers control the data that is stored in a config entry. This means that there is no need to validate that the config is correct when Home Assistant starts up. It will also prevent breaking changes because we will be able to migrate configuration entries to new formats if the version changes.
When instantiating the handler, Home Assistant will make sure to load all dependencies and install the requirements of the integration.
Updating the manifest​
You need to update your integrations manifest to inform Home Assistant that your integration has a config flow. This is done by adding config_flow: true to your manifest (docs).
Defining your config flow​
Config entries use the data flow entry framework to define their config flows. The config flow needs to be defined in the file config_flow.py in your integration folder, extend homeassistant.config_entries.ConfigFlow and pass a domain key as part of inheriting ConfigFlow.
from homeassistant import config_entries
from .const import DOMAIN
class ExampleConfigFlow(config_entries.ConfigFlow, domain=DOMAIN):
"""Example config flow."""
Once you have updated your manifest and created the config_flow.py, you will need to run python3 -m script.hassfest (one time only) for Home Assistant to activate the config entry for your integration.
Config flow title​
The title of a config flow can be influenced by integrations, and is determined in this priority order:
  1. If title_placeholders is set to a non-empty dictionary in the config flow, it will be used to dynamically calculate the config flow's title. Reauth and reconfigure flows automatically set title_placeholders to {"name": config_entry_title}.
    1. If the integration provides a localized flow_title, that will be used, with any translation placeholders substituted from the title_placeholders.
    2. If the integration does not provide a flow_title but the title_placeholders includes a name, the name will be used as the flow's title.
  2. Set the flow title to the integration's localized title, if it exists.
  3. Set the flow title to the integration manifest's name, if it exists.
  4. Set the flow title to the integration's domain.
Note that this priority order means that:
  • A localized flow_title is ignored if the title_placeholders dictionary is missing or empty, even if the localized flow_title does not have any placeholders
  • If title_placeholders is not empty, but there's no localized flow_title and the title_placeholders does not include a name, it is ignored.
Defining steps​
Your config flow will need to define steps of your configuration flow. Each step is identified by a unique step name (step_id). The step callback methods follow the pattern async_step_<step_id>. The docs for Data Entry Flow describe the different return values of a step. Here is an example of how to define the user step:
import probatio
async def async_step_user(self, info):
if info is not None:
pass # TODO: process info
return self.async_show_form(
step_id="user",
data_schema=probatio.Schema({probatio.Required("password"): str}),
There are a few step names reserved for system use:
Step nameDescription
bluetoothInvoked if your integration has been discovered via Bluetooth as specified using bluetooth in the manifest.
discoveryDEPRECATED Invoked if your integration has been discovered and the matching step has not been defined.
dhcpInvoked if your integration has been discovered via DHCP as specified using dhcp in the manifest.
hassioInvoked if your integration has been discovered via a Supervisor add-on.
homekitInvoked if your integration has been discovered via HomeKit as specified using homekit in the manifest.
mqttInvoked if your integration has been discovered via MQTT as specified using mqtt in the manifest.
ssdpInvoked if your integration has been discovered via SSDP/uPnP as specified using ssdp in the manifest.
usbInvoked if your integration has been discovered via USB as specified using usb in the manifest.
userInvoked when a user initiates a flow via the user interface or when discovered and the matching and discovery step are not defined.
reconfigureInvoked when a user initiates a flow to reconfigure an existing config entry via the user interface.
zeroconfInvoked if your integration has been discovered via Zeroconf/mDNS as specified using zeroconf in the manifest.
reauthInvoked if your integration indicates it requires reauthentication, for example, due to expired credentials.
importReserved for migrating from YAML configuration to config entries.
Unique IDs​
A config flow can attach a unique ID, which must be a string, to a config flow to avoid the same device being set up twice. The unique ID does not need to be globally unique, it only needs to be unique within an integration domain.
By setting a unique ID, users will have the option to ignore the discovery of your config entry. That way, they won't be bothered about it anymore. If the integration uses Bluetooth, DHCP, HomeKit, Zeroconf/mDNS, USB, or SSDP/uPnP to be discovered, supplying a unique ID is required.
If a unique ID isn't available, alternatively, the bluetooth, dhcp, zeroconf, hassio, homekit, ssdp, usb, and discovery steps can be omitted, even if they are configured in the integration manifest. In that case, the user step will be called when the item is discovered.
Alternatively, if an integration can't get a unique ID all the time (for example, multiple devices, some have one, some don't), a helper is available that still allows for discovery, as long as there aren't any instances of the integration configured yet.
Here's an example of how to handle discovery where a unique ID is not always available:
if device_unique_id:
await self.async_set_unique_id(device_unique_id)
else:
await self._async_handle_discovery_without_unique_id()
Managing Unique IDs in Config Flows​
When a unique ID is set, the flow will immediately abort if another flow is in progress for this unique ID. You can also quickly abort if there is already an existing config entry for this ID. Config entries will get the unique ID of the flow that creates them.
Call inside a config flow step:
# Assign a unique ID to the flow and abort the flow
# if another flow with the same unique ID is in progress
# Abort the flow if a config entry with the same unique ID exists
self._abort_if_unique_id_configured()
Should the config flow then abort, the text resource with the key already_configured from the abort part of your strings.json will be displayed to the user in the interface as an abort reason.
"config": {
"abort": {
"already_configured": "[%key:common::config_flow::abort::already_configured_device%]"
Unique ID requirements​
A unique ID is used to match a config entry to the underlying device or API. The unique ID must be stable, should not be able to be changed by the user and must be a string.
The Unique ID can be used to update the config entry data when device access details change. For example, for devices that communicate over the local network, if the IP address changes due to a new DHCP assignment, the integration can use the Unique ID to update the host using the following code snippet:
await self.async_set_unique_id(serial_number)
self._abort_if_unique_id_configured(updates={CONF_HOST: host, CONF_PORT: port})
Example acceptable sources for a unique ID​
  • Serial number of a device
  • MAC address: formatted using homeassistant.helpers.device_registry.format_mac; Only obtain the MAC address from the device API or a discovery handler. Tools that rely on reading the arp cache or local network access such as getmac will not function in all supported network environments and are not acceptable.
  • A string representing the latitude and longitude or other unique geo location
  • Unique identifier that is physically printed on the device or burned into an EEPROM
Sometimes acceptable sources for a unique ID for local devices​
  • Hostname: If a subset of the hostname contains one of the acceptable sources, this portion can be used
Sometimes acceptable sources for a unique ID for cloud services​
  • Email Address: Must be normalized to lowercase
  • Username: Must be normalized to lowercase if usernames are case-insensitive.
  • Account ID: Must not have collisions
Unacceptable sources for a unique ID​
  • IP Address
  • Device Name
  • Hostname if it can be changed by the user
  • URL
Discovery steps​
When an integration is discovered, their respective discovery step is invoked (ie async_step_dhcp or async_step_zeroconf) with the discovery information. The step will have to check the following things:
  • Make sure there are no other instances of this config flow in progress of setting up the discovered device. This can happen if there are multiple ways of discovering that a device is on the network.
    • In most cases, it's enough to set the unique ID on the flow and check if there's already a config entry with the same unique ID as explained in the section about managing unique IDs in config flows
    • In some cases, a unique ID can't be determined, or the unique ID is ambiguous because different discovery sources may have different ways to calculate it. In such cases:
      1. Implement the method def is_matching(self, other_flow: Self) -> bool on the flow.
      2. Call hass.config_entries.flow.async_has_matching_flow(self).
      3. Your flow's is_matching method will then be called once for each other ongoing flow.
  • Make sure that the device is not already set up.
  • Invoking a discovery step should never result in a finished flow and a config entry. Always confirm with the user.
Discoverable integrations that require no authentication​
If your integration is discoverable without requiring any authentication, you'll be able to use the Discoverable Flow that is built-in. This flow offers the following features:
  • Detect if devices/services can be discovered on the network before finishing the config flow.
  • Support all manifest-based discovery protocols.
  • Limit to only 1 config entry. It is up to the config entry to discover all available devices.
To get started, run python3 -m script.scaffold config_flow_discovery and follow the instructions. This will create all the boilerplate necessary to configure your integration using discovery.
Configuration via OAuth2​
Home Assistant has built-in support for integrations that offer account linking using the OAuth2 authorization framework. To be able to leverage this, you will need to structure your Python API library in a way that allows Home Assistant to be responsible for refreshing tokens. See our API library guide on how to do this.
The built-in OAuth2 support works out of the box with locally configured client ID / secret using the Application Credentials platform and with the Home Assistant Cloud Account Linking service. This service allows users to link their account with a centrally managed client ID/secret. If you want your integration to be part of this service, reach out to us at [email protected].
To get started, run python3 -m script.scaffold config_flow_oauth2 and follow the instructions. This will create all the boilerplate necessary to configure your integration using OAuth2.
Translations​
Translations for the config flow handlers are defined under the config key in the integration translation file strings.json. Example of the Hue integration:
"title": "Philips Hue Bridge",
"config": {
"step": {
"init": {
"title": "Pick Hue bridge",
"data": {
"host": "Host"
"link": {
"title": "Link Hub",
"description": "Press the button on the bridge to register Philips Hue with Home Assistant.\n\n![Location of button on bridge](/static/images/config_philips_hue.jpg)"
"error": {
"register_failed": "Failed to register, please try again",
"linking": "Unknown linking error occurred."
"abort": {
"discover_timeout": "Unable to discover Hue bridges",
"no_bridges": "No Philips Hue bridges discovered",
"all_configured": "All Philips Hue bridges are already configured",
"unknown": "Unknown error occurred",
"cannot_connect": "Unable to connect to the bridge",
"already_configured": "Bridge is already configured"
When the translations are merged into Home Assistant, they will be automatically uploaded to Lokalise where the translation team will help to translate them in other languages. While developing locally, you will need to run python3 -m script.translations develop to see changes made to strings.json More info on translating Home Assistant.
Config entry migration​
Each config entry has a version assigned to it, made up of a major and a minor version. This is to be able to migrate config entry data to new formats when the config entry schema changes. Both VERSION and MINOR_VERSION default to 1 if not explicitly set in the config flow, so integrations only need to set them when implementing a migration.
Migration can be handled programmatically by implementing function async_migrate_entry in your integration's __init__.py file. The function should return True if migration is successful.
Handle returns, raise exceptions in migrations​
Returns / RaisesDescription
return TrueMigration successful, setup continues
return FalseMigration not successful, setup stops with config entry state migration_error
raise ConfigEntryNotReadyMigration not successful, setup stops and will retry later
raise ExceptionMigration not successful, setup stops with config entry state migration_error
note
Prefer raising ConfigEntryNotReady (when a retry is wanted) or ConfigEntryError instead of returning False. Both exceptions support translations, so you can give the user more context about what went wrong.
tip
Config entry state migration_error is non-recoverable. When the user can fix the problem, use a repair. To retry the migration, call hass.config_entries.async_retry_migration(entry_id) from the repair flow once the user has fixed the problem.
If minor versions differ but major versions are the same, integration setup will be allowed to continue even if the integration does not implement async_migrate_entry. This means a minor version bump is backwards compatible unlike a major version bump which causes the integration to fail setup if the user downgrades Home Assistant Core without restoring their configuration from backup.
To set a new version, add VERSION and/or MINOR_VERSION to your config flow class:
VERSION = 2
MINOR_VERSION = 2
# Example migration function
async def async_migrate_entry(hass, config_entry: ConfigEntry):
"""Migrate old entry."""
_LOGGER.debug("Migrating configuration from version %s.%s", config_entry.version, config_entry.minor_version)
if config_entry.version == 1:
new_data = {**config_entry.data}
if config_entry.minor_version < 2:
# TODO: modify Config Entry data with changes in version 1.2
pass
if config_entry.minor_version < 3:
# TODO: modify Config Entry data with changes in version 1.3
pass
hass.config_entries.async_update_entry(
config_entry, data=new_data, minor_version=3, version=1
_LOGGER.debug("Migration to configuration version %s.%s successful", config_entry.version, config_entry.minor_version)
return True
Reconfigure​
A config entry can allow reconfiguration by adding a reconfigure step. This provides a way for integrations to allow users to change config entry data without the need to implement an OptionsFlow for changing setup data which is not meant to be optional.
This is not meant to handle authentication issues or reconfiguration of such. For that we have the reauth step, which should be implemented to automatically start in such case there is an issue with authentication.
import probatio
"""Config flow for Example integration."""
async def async_step_reconfigure(self, user_input: dict[str, Any] | None = None):
if user_input is not None:
# TODO: process user input
await self.async_set_unique_id(user_id)
self._abort_if_unique_id_mismatch()
return self.async_update_reload_and_abort(
self._get_reconfigure_entry(),
data_updates=data,
step_id="reconfigure",
data_schema=probatio.Schema({probatio.Required("input_parameter"): str}),
On success, reconfiguration flows are expected to update the current entry and abort; they should not create a new entry. This is usually done with the return self.async_update_reload_and_abort helper. Automated tests should verify that the reconfigure flow updates the existing config entry and does not create additional entries.
Checking whether you are in a reconfigure flow can be done using if self.source == SOURCE_RECONFIGURE. It is also possible to access the corresponding config entry using self._get_reconfigure_entry(). Ensuring that the unique_id is unchanged should be done using await self.async_set_unique_id followed by self._abort_if_unique_id_mismatch().
Reauthentication​
Gracefully handling authentication errors such as invalid, expired, or revoked tokens is needed to advance on the Integration Quality Scale. This example of how to add reauth to the OAuth flow created by script.scaffold following the pattern in Building a Python library. If you are looking for how to trigger the reauthentication flow, see handling expired credentials.
This example catches an authentication exception in config entry setup in __init__.py and instructs the user to visit the integrations page to reconfigure the integration.
To allow the user to change config entry data which is not optional (OptionsFlow) and not directly related to authentication, for example a changed host name, integrations should implement the reconfigure step.
from homeassistant.config_entries import SOURCE_REAUTH, ConfigEntry
from . import api
async def async_setup_entry(hass: HomeAssistant, entry: ConfigEntry):
"""Set up a config entry."""
# TODO: Replace with actual API setup and exception
auth = api.AsyncConfigEntryAuth(...)
try:
await auth.refresh_tokens()
except TokenExpiredError as err:
raise ConfigEntryAuthFailed(err) from err
# TODO: Proceed with integration setup
The flow handler in config_flow.py also needs to have some additional steps to support reauth which include showing a confirmation, starting the reauth flow, updating the existing config entry, and reloading to invoke setup again.
class OAuth2FlowHandler(
config_entry_oauth2_flow.AbstractOAuth2FlowHandler, domain=DOMAIN
"""Config flow to handle OAuth2 authentication."""
async def async_step_reauth(
self, entry_data: Mapping[str, Any]
) -> ConfigFlowResult:
"""Perform reauth upon an API authentication error."""
return await self.async_step_reauth_confirm()
async def async_step_reauth_confirm(
"""Dialog that informs the user that reauth is required."""
if user_input is None:
step_id="reauth_confirm",
data_schema=probatio.Schema({}),
return await self.async_step_user()
async def async_oauth_create_entry(self, data: dict) -> dict:
"""Create an oauth config entry or update existing entry for reauth."""
if self.source == SOURCE_REAUTH:
self._get_reauth_entry(),
data_updates=data,
return await super().async_oauth_create_entry(data)
By default, the async_update_reload_and_abort helper method aborts the flow with reauth_successful after update and reload. By default, the entry will always be reloaded. If the config entry only should be reloaded in case the config entry was updated, specify reload_even_if_entry_is_unchanged=False.
Depending on the details of the integration, there may be additional considerations such as ensuring the same account is used across reauth, or handling multiple config entries.
The reauth confirmation dialog needs an additional definition in strings.json:
"config": {
"step": {
"reauth_confirm": {
"title": "[%key:common::config_flow::title::reauth%]",
# TODO: Replace with the name of the integration
"description": "The Example integration needs to re-authenticate your account"
See Translations local development instructions.
Authentication failures (such as a revoked oauth token) can be a little tricky to manually test. One suggestion is to make a copy of config/.storage/core.config_entries and manually change the values of access_token, refresh_token, and expires_at depending on the scenario you want to test. You can then walk advance through the reauth flow and confirm that the values get replaced with new valid tokens.
On success, reauth flows are expected to update the current entry and abort; they should not create a new entry. This is usually done with the return self.async_update_reload_and_abort helper. Automated tests should verify that the reauth flow updates the existing config entry and does not create additional entries.
Checking whether you are in a reauth flow can be done using if self.source == SOURCE_REAUTH. It is also possible to access the corresponding config entry using self._get_reauth_entry(). Ensuring that the unique_id is unchanged should be done using await self.async_set_unique_id followed by self._abort_if_unique_id_mismatch().
Subentry flows​
An integration can implement subentry flows to allow users to add, and optionally reconfigure, subentries. An example of this is an integration providing weather forecasts, where the config entry stores authentication details and each location for which weather forecasts should be provided is stored as a subentry.
Subentry flows are similar to config flows, except that subentry flows don't support reauthentication or discovery; a subentry flow can only be initiated via the user or reconfigure steps.
@classmethod
@callback
def async_get_supported_subentry_types(
cls, config_entry: ConfigEntry
) -> dict[str, type[ConfigSubentryFlow]]:
"""Return subentries supported by this integration."""
return {"location": LocationSubentryFlowHandler}
class LocationSubentryFlowHandler(ConfigSubentryFlow):
"""Handle subentry flow for adding and modifying a location."""
) -> SubentryFlowResult:
"""User flow to add a new location."""
Subentry unique ID​
Subentries can set a unique ID. The rules are similar to unique IDs of config entries, except that subentry unique IDs only need to be unique within the config entry.
Subentry translations​
Translations for subentry flow handlers are defined under the config_subentries key in the integration translation file strings.json, for example:
"config_subentries": {
"location": {
"title": "Weather location",
"step": {
"user": {
"title": "Add location",
"description": "Configure the weather location"
"reconfigure": {
"title": "Update location",
"description": "..."
"error": {
"abort": {
Subentry reconfigure​
Subentries can be reconfigured, similar to how config entries can be reconfigured. To add support for reconfigure to a subentry flow, implement a reconfigure step.
"""User flow to modify an existing location."""
# Retrieve the parent config entry for reference.
config_entry = self._get_entry()
# Retrieve the specific subentry targeted for update.
config_subentry = self._get_reconfigure_subentry()
Continuing in another flow​
A config flow can start another config flow and tell the frontend that it should show the other flow once the first flow is finished. To do this the first flow needs to pass the next_flow parameter to the async_create_entry method. The argument should be a tuple of the form (flow_type, flow_id).
from homeassistant.config_entries import SOURCE_USER, ConfigFlow, FlowType
class ExampleFlow(ConfigFlow):
"""Example flow."""
"""Show create entry with next_flow parameter."""
result = await self.hass.config_entries.flow.async_init(
"another_integration_domain",
context={"source": SOURCE_USER},
return self.async_create_entry(
title="Example",
data={},
next_flow=(FlowType.CONFIG_FLOW, result["flow_id"]),
Use async_on_create_entry​
The async_on_create_entry provides an option to modify the final ConfigFlowResult after the config entry has been created and the flow finalizes.
As subentry flows and option flows are dependent on that the main config entry exist before they can be started, these flow types can only be used with the async_on_create_entry() method in your config flow:
from homeassistant.config_entries import (
ConfigFlow,
FlowType,
SOURCE_USER,
SubentryFlowContext,
"""Example flow."""
async def async_on_create_entry(
self, result: ConfigFlowResult
"""Create subentry flow after creating the main entry."""
subentry_result = await self.hass.config_entries.subentries.async_init(
(result["result"].entry_id, "subentry_type"),
context=SubentryFlowContext(source=SOURCE_USER),
result["next_flow"] = (
FlowType.CONFIG_SUBENTRIES_FLOW,
subentry_result["flow_id"],
return result
"""Create entry."""
title="Example",
data={},
Use SchemaConfigFlowHandler for simple flows​
For helpers and integrations with simple config flows, you can use the SchemaConfigFlowHandler instead.
Compared to using a full config flow, the SchemaConfigFlowHandler comes with certain limitations and needs to be considered:
  • All user input is saved in the options dictionary of the resulting config entry. Therefore it's not suitable to use in integrations which uses connection data, api key's or other information that should be stored in the config entry data.
  • It may be simpler to use the normal config flow handler if you have extensive validation, setting unique id or checking for duplicated config entries.
  • Starting the flow with other steps besides user and import is discouraged.
from homeassistant.helpers.schema_config_entry_flow import (
SchemaCommonFlowHandler,
SchemaConfigFlowHandler,
SchemaFlowError,
SchemaFlowFormStep,
async def validate_setup(
handler: SchemaCommonFlowHandler, user_input: dict[str, Any]
) -> dict[str, Any]:
"""Validate options."""
if user_input[CONF_SOME_SETTING] == "error":
# 'setup_error' needs to be existing in string.json config errors section
raise SchemaFlowError("setup_error")
return user_input
DATA_SCHEMA_SETUP = probatio.Schema(
probatio.Required(CONF_NAME, default=DEFAULT_NAME): TextSelector()
DATA_SCHEMA_OPTIONS = probatio.Schema(
probatio.Optional(CONF_SOME_SETTING): TextSelector()
CONFIG_FLOW = {
"user": SchemaFlowFormStep(
schema=DATA_SCHEMA_SETUP,
next_step="options",
"options": SchemaFlowFormStep(
schema=DATA_SCHEMA_OPTIONS,
validate_user_input=validate_setup,
OPTIONS_FLOW = {
"init": SchemaFlowFormStep(
class MyConfigFlowHandler(SchemaConfigFlowHandler, domain=DOMAIN):
"""Handle a config flow."""
config_flow = CONFIG_FLOW
options_flow = OPTIONS_FLOW
options_flow_reloads = True # Reload without a config entry listener
def async_config_entry_title(self, options: Mapping[str, Any]) -> str:
"""Return config entry title from input."""
return cast(str, options[CONF_NAME])
Testing your config flow​
Integrations with a config flow require full test coverage of all code in config_flow.py to be accepted into core. Test your code includes more details on how to generate a coverage report.
