Supervisor update
It's been a while since we posted about changes to the Supervisor. Here are some highlights from the past year and the future. This information is mainly for add-on developers, but there is little something for everyone in here. If you have not yet seen it, we have posted a blog on the main site that you should read.
Snapshot -> Backup
First up, as mentioned in the blog on the main site, we have started a transition away from the name "snapshot" that has been with us since the beginning of the Supervisor and are now moving to the more recognizable "backup".
These changes are live now on the dev channel for the Supervisor, so you can start testing and adjusting your tools/add-ons to make sure they will still work when your users get this.
API changes
With the transition from "snapshot" to "backup", a new base section in the Supervisor API has been added /backups that operates the same way as /snapshots with all the same endpoints as the old section has but there are two key differences:
- If you access
/backupsthe data returned now will be{"backups": []}instead of{"snapshots": []} - To delete a snapshot you now have to use the
DELETEHTTP method with the/backupsendpoint, previously bothPOSTandDELETEwere supported.
The old /snapshots endpoints are now deprecated and are scheduled for removal in Q4 of this year.
Backup structure changes
For consistency, we have also changed the name of the meta file inside the backup tar from snapshot.json to backup.json. If you have a tool that uses that file you should look for both so your tool will work for existing as well as new backups.
Streaming ingress
Some add-ons need to receive large payloads from the user, for instance with uploading. Previously, there has been a limit of 16 MB per request for add-ons running behind ingress and this is still the default. If you need to receive larger payloads, you can enable this by setting ingress_stream to True in the add-on configuration. When you do this the request is streamed from the client to your add-on, and the request has no size limit and virtually no overhead.
Note that not all webservers are able to handle this by default, so you might need to adjust it.
Deprecated API endpoints
Over the past years, we have restructured parts of our API endpoints, but we have also kept old endpoints working. If you use any of the deprecated endpoints in your tools/add-ons you should move to use the new ones now. All deprecated endpoints are scheduled for removal in Q4 this year.
Here is a list of the deprecated endpoints and their replacements:
| Deprecated endpoints | Replaced with |
/homeassistant/* | /core/* |
/snapshots/* | /backups/* |
In addition to this, the following are also deprecated and are also scheduled for removal in Q4 this year.
- The environment variable
HASSIO_TOKENhas been replaced withSUPERVISOR_TOKEN. - Using
X-Hassio-Keyheader has been replaced with usingAuthorizationwith a Bearer token. - Using
http://hassio/to communicate with the Supervisor has been replaced withhttp://supervisor/.
Supervised installation
Maintaining a supervised installation is currently not the best experience. The script that most users use to install is behind what the Supervisor wants from the host. Since there are no real upgrade paths for those using it, users of it need to manually adjust their installation.
Recently we created the OS Agent as mentioned in the blog on the main site. This allows for better communication between the host OS and the Supervisor, and to bring in more features. To take advantage of these features users of current supervised installations have to install the OS Agent manually.
An alternative to this route is to package and distribute the supervised installation as a deb package that can be installed and upgraded with apt on the host. For this to be viable, we are looking for a person (or a group of people) that wants to create and maintain this type of deployment, and bring the supervised installation method up to par with our OS, and more importantly make updates needed on the host easier for the users.
If you have questions about these changes feel free to reach out in the #devs_supervisor channel on our Discord server.
Until next time 👋
