Updated guidelines for helper integrations linking to other integration's device
Helper integrations should not add their own config entries to the source entity's device or to a user selected device. Instead, they should just link their entities to the device of the source entity.
Adding the helper config entry to another integration's device is no longer supported and will stop working in Home Assistant Core 2026.8.
Background
The architecture proposal home-assistant/architecture#1226 makes device connections and identifiers unique per integration domain instead of globally unique. This is not an issue for most integrations, but helper integrations with config flows are an exception.
Suggested change
Link the helper entity directly to the source integration's device
In the helper entity's constructor, set self.device_entry to the source device
class HelperEntity(Entity)
    def __init__(hass: HomeAssistant, source_entity_id: str, ...) -> None:
        self.device_entry = async_entity_id_to_device(
            hass,
            source_entity_id,
Do not add the helper config entry to the source device directly
Do not add the config entry to the source device directly, meaning that this pattern is no longer allowed
device_registry.async_update_device(
    source_device.id,
    add_config_entry_id=helper_config_entry.entry_id,
Do not add the helper config entry to the source device implicitly
Don’t set self._attr_device_info and don’t override device_info to return identifiers and connections for a device from another integration as that will mean the helper config entry is added to the source device. Instead, Set self.device_entry in the helper entity to link the helper entity to another integration's device as in the example above.
Cleaning up the device registry
A helper function, homeassistant.helpers.helper_integration.async_remove_helper_config_entry_from_source_device is available to aid the clean up. Core integrations have been modified to call this helper from a config entry migration step.
Handling removed devices
It is up to the helper integration to decide how to handle a removed device; most core helpers set self.device_entry to None. Note that DeviceRegistry.async_get returns None if passed a device_id which doesn't exist.
Sample implementations
The derivative core integration, which previously added its config entry to the source entity's device, has been updated to just link the helper entity to the source entity's device in core PR #148674.
The template core integration, which previously added its config entry to a user selected device, has been updated to just link the helper entity to the user selected device in core PR #148756.
