Add a status callback for MQTT subscriptions
Integrations that use MQTT might need to wait for a subscription to complete before they initiate actions. The default behavior is that a subscription is queued and debounced, so callers usually do not wait for broker confirmation. Some integrations must guarantee that the broker finished the subscription. To support this requirement, the MQTT subscribe API adds a on_subscribe callback option.
The new async signature for MQTT subscribe that supports the new callback option is:
@bind_hass
async def async_subscribe(
hass: HomeAssistant,
topic: str,
msg_callback: Callable[[ReceiveMessage], Coroutine[Any, Any, None] | None],
qos: int = DEFAULT_QOS,
encoding: str | None = DEFAULT_ENCODING,
on_subscribe: CALLBACK_TYPE,
) -> CALLBACK_TYPE:
"""Subscribe to an MQTT topic.
Call the return value to unsubscribe.
Example where we want to publish a status update after the subscription is ready:
from homeassistant.components import mqtt
async def async_setup_entry(hass: HomeAssistant, entry: ConfigEntry) -> bool:
"""Setup integration with awaited MQTT subscription."""
@callback
def async_subscribe_callback(msg: ReceiveMessage) -> None:
"""Callback example."""
# Do stuff
def _on_subscribe_status() -> None:
"""Publish an online state when we are ready to receive updates."""
hass.async_create_task(
mqtt.async_publish(
hass, "myintegration/status", "online", 0, retain=True
# Subscribe and wait
unsubscribe_callback = await mqtt.async_subscribe(
hass,
"myintegration/updates",
async_subscribe_callback,
qos=1,
on_subscribe=_on_subscribe_status
# Do some stuff
Monitor subscription status with the helper function
In case a subscription is already pending, or when we want to keep monitoring, the mqtt.async_on_subscribe_done helper can be used to monitor its subscription, to allow doing additional task. Make sure the same QoS is used.
Example:
"""Setup integration MQTT subscription monitoring."""
"""Handle subscription ready signal."""
# Do stuff
# Handle subscription ready status update
await mqtt.async_on_subscribe_done(
hass,
qos=1,
on_subscribe_status=_on_subscribe_status,
# Do stuff
