Frontend new way of dialogs
· One min read
The Problem
Each dialog managed by the dialog manager was only opened once and stayed in the DOM for the lifetime of the application. This causes:
  • More memory usage: Dialogs accumulate in the DOM even when not visible
  • More bugs because of missing state reset: Dialog state persists between opens, leading to stale data or unexpected behavior
The Solution: DialogMixin
We implemented a new way of handling dialogs using DialogMixin. With this approach:
  • Dialogs are created when opened and destroyed when closed: No need to manually reset the state of the dialog when it is closed
  • Closed events are automatically handled: The dialog mixin takes care of cleanup
  • Subscribe mixin can now be used in dialogs: Since dialogs are properly destroyed, subscriptions are cleaned up automatically
  • Use normal Lit lifecycle methods: Use connectedCallback to initialize when the dialog is opened instead of relying on the showDialog method
Example
Check out ha-dialog-date-picker for a reference implementation. DialogMixin adds dialog params to this.params if available.
