New infrared entity platform for IR device integrations
· 2 min read
Home Assistant now has an infrared entity platform that decouples IR emitter hardware from the devices they control. Instead of each device integration talking directly to specific IR hardware, emitter integrations (like esphome) expose InfraredEntity instances, and device integrations (like lg_infrared) send commands through them via helper functions.
See the architecture discussion for the full background.
Architecture
The infrared domain sits between two types of integrations:
  • Emitter integrations (ESPHome, Broadlink, …) implement the InfraredEntity base class to provide hardware-specific IR transmission.
  • Consumer integrations (LG, Samsung, Daikin, …) use helper functions to send device-specific IR commands through available emitters.
Users select which emitter to use during the consumer integration's config flow.
Implementing an emitter integration
Emitter integrations provide the infrared platform by subclassing InfraredEntity and implementing async_send_command. The command's get_raw_timings() method returns protocol-agnostic timing data that the hardware can transmit:
from homeassistant.components.infrared import InfraredCommand, InfraredEntity
class MyInfraredEntity(InfraredEntity):
"""My IR transmitter."""
async def async_send_command(self, command: InfraredCommand) -> None:
"""Send an IR command."""
timings = [
interval
for timing in command.get_raw_timings()
for interval in (timing.high_us, -timing.low_us)
await self._device.transmit(
carrier_frequency=command.modulation,
timings=timings,
The raw protocol-agnostic timings should be converted to the specific format required by the hardware.
Building a consumer integration
Consumer integrations control IR devices by sending commands through an emitter entity. They don't interact with IR hardware directly.
1. Declare the dependency in manifest.json:
"dependencies": ["infrared"]
2. Let the user pick an emitter in the config flow:
from homeassistant.components import infrared
emitters = infrared.async_get_emitters(hass)
if not emitters:
return self.async_abort(reason="no_emitters")
3. Send IR commands using the helper function and the infrared-protocols library:
from infrared_protocols.codes.lg.tv import LGTVCode, make_lg_tv_command
await infrared.async_send_command(
hass,
self._infrared_entity_id,
make_lg_tv_command(LGTVCode.VOLUME_UP),
context=self._context,
IR protocols and codes
IR protocol encoders and device code sets live outside Home Assistant in the infrared-protocols library. Common protocols (NEC, Samsung, etc.) and well-known device codes used by core integrations should be contributed there. For niche or proprietary protocols, a separate third-party library can also be used.
For full details, see the infrared entity documentation.
