Changes to the condition and script APIs
· 2 min read
Summary
The condition and script APIs have been changed.
Conditions are now instances of condition classes, which are evaluated by calling the async_check method and discarded by calling the async_unload method. Also, conditions may optionally implement an _async_setup or _async_unload method. Note that users of conditions don't need to call the condition's async_setup method.
During a deprecation period, which ends with the release of Home Assistant Core 2027.1, it's possible to use the condition object as a callable.
Scripts also have an async_unload method which must be called when the script is no longer needed.
Impact on custom integrations
Custom integrations which create conditions or scripts
Custom integrations which create condition objects should evaluate them by calling the async_check method and call the async_unload method when the condition is no longer needed.
Example:
from homeassistant.helpers.condition import (
async_condition_from_config,
async_validate_condition_config,
# Validate condition config
validated_config = await async_validate_condition_config(hass, config)
# Create a condition
condition = await async_condition_from_config(hass, validated_config)
# Evaluate the condition
result = condition.async_check(...)
# Discard the condition
condition.async_unload()
Custom integrations which create scripts should call the async_unload method when the script is no longer needed.
Example:
from homeassistant.helpers.script import (
Script,
async_validate_actions_config,
# Validate script config
validated_config = await async_validate_actions_config(hass, config)
# Create a script
script = Script(hass, validated_config, ...)
# Execute the script
result = await script.async_run(...)
# Discard the script
await script.async_unload()
Custom integrations which provide a condition platform
Integrations which provide a condition platform don't need to change, but may implement _async_setup and _async_unload method if the platform needs to perform async initialization or do tear down.
Example:
Condition,
ConditionCheckParams,
ConditionConfig,
from homeassistant.helpers.typing import ConfigType
class CustomCondition(Condition):
"""A custom condition."""
@classmethod
async def async_validate_config(
cls, hass: HomeAssistant, config: ConfigType
) -> ConfigType:
"""Validate config."""
def __init__(self, hass: HomeAssistant, config: ConditionConfig) -> None:
"""Initialize condition."""
super().__init__(hass, config)
async def _async_setup(self) -> None:
"""Set up the condition checker."""
def _async_unload(self) -> None:
"""Clean up any resources held by the checker."""
def _async_check(self, **kwargs: Unpack[ConditionCheckParams]) -> bool:
"""Check the condition."""
