Changes in setup entity platforms with group integration
· 2 min read
By default, the group integration allows entities to be grouped. If the default ON/OFF states for an entity default to on and off, then grouping is supported by default. The setup changes, though, for Entity platforms that can be grouped but have alternative states, e.g., cover (open/closed) or person (home/not_home), or platforms that are meant to be excluded, such as sensor. These entity platforms must implement async_describe_on_off_states in the group.py module.
In async_describe_on_off_states, the domain needs to be the first argument passed to the registry methods on_off_states and exclude_domain. When registering alternative ON/OFF states with registry.on_off_state, in addition to the ON states, the default ON state needs to be passed.
Example registering alternative states
New signature for registry.on_off_states:
@callback
def on_off_states(
self, domain: str, on_states: set[str], default_on_state:str, off_state: str
) -> None:
"""Register on and off states for the current domain."""
Example group.py for the vacuum entity platform registering alternative ON/OFF states. Note the the first ON state now is considered to be the default ON state.
"""Describe group states."""
from typing import TYPE_CHECKING
from homeassistant.const import STATE_OFF, STATE_ON
from homeassistant.core import HomeAssistant, callback
if TYPE_CHECKING:
from homeassistant.components.group import GroupIntegrationRegistry
from .const import DOMAIN, STATE_CLEANING, STATE_ERROR, STATE_RETURNING
@callback
def async_describe_on_off_states(
hass: HomeAssistant, registry: "GroupIntegrationRegistry"
) -> None:
"""Describe group on off states."""
registry.on_off_states(
DOMAIN, # domain
# set with all group ON states
STATE_ON,
STATE_CLEANING,
STATE_RETURNING,
STATE_ERROR,
STATE_ON, # Default group ON state
STATE_OFF, # Group OFF state
Example excluding an entity platform from group entities
New signature for registry.exclude_domain:
@callback
def exclude_domain(self, domain: str) -> None:
"""Exclude the current domain."""
Example group.py for the sensor entity platform to exclude sensor entities from group entities.
if TYPE_CHECKING:
@callback
) -> None:
registry.exclude_domain(DOMAIN)
