The result attribute has been removed from the FlowResult typed dict
· One min read
The result attribute has been removed from the homeassistant.data_entry_flow.FlowResult
typed dict, and is now present only when needed, i.e. homeassistant.auth.models.AuthFlowResult
and homeassistant.config_entries.ConfigFlowResult
The change is not expected to affect runtime behavior of custom integrations, but custom integration authors may need to update tests and any classes derived from homeassistant.data_entry_flow.FlowResult
that use a result
attribute, to silence type-checker warnings.
