Additional validation in Climate set temperature
As of Home Assistant Core 2024.10, we have added further validation of the parameters passed to the set_temperature
method. This means that integrations don't need to implement this validation in their own methods.
Before 2024.10 it was possible to set the temperature
parameter in the action when the entity did not set ClimateEntityFeature.TARGET_TEMPERATURE
or target_temp_low
/target_temp_high
parameters when the entity did not set ClimateEntityFeature.TARGET_TEMPERATURE_RANGE
. This will no longer be possible and a ServiceValidationError
will be raised informing the user that they used an incorrect parameter in the action call.
Also, when setting a temperature range, it was possible to set target_temp_low
to a higher value than target_temp_high
This will raise a ServiceValidationError
informing the user the high value needs to be higher than the low value.
