Set up your DataUpdateCoordinator with a setup method
· One min read
In Home Assistant 2024.8, we are introducing the _async_setup method for the data update coordinator.
This method allows you to run asynchronous code to prepare your DataUpdateCoordinator instance
or to load data that only needs to be loaded once.
You can override _async_setup in your coordinator, and it will be automatically
called during coordinator.async_config_entry_first_refresh().
It offers the same error handling as _async_update_data and will handle ConfigEntryError
and ConfigEntryAuthFailed accordingly.
Example
class MyUpdateCoordinator(DataUpdateCoordinator[MyDataType]):
prereq_data: SomeData
def __init__(
self,
hass: HomeAssistant,
) -> None:
"""Initialize coordinator."""
super().__init__(hass, _LOGGER, name=DOMAIN, update_interval=SCAN_INTERVAL)
self.my_api = MyApi()
async def _async_setup(self) -> None:
"""Do initialization logic."""
self.prereq_data = await self.my_api.get_initial_data()
async def _async_update_data(self) -> MyDataType:
"""Do the usual update"""
return await self.my_api.update(self.prereq_data)
Avoiding checks for initialization status
This change allows you to refactor code that loaded the initial data in
the _async_update_data method by checking an initialization variable, like
async def _async_update_data(self) -> ...:
if not self.something:
self.something = self.client.fetch()
return self.client.fetch_data()
into
More information
Read more about this in the documentation
