Config processing and error handling
· 2 min read
Changes in component config processing and error handling
The way component YAML configuration is processed has been changed. Now, it is possible to raise if an error occurs. Some custom integrations might break if they are using config.async_process_component_config. Instead, they can use config.async_process_component_and_handle_errors now. This new method supports raising when an error occurs during config processing. From now on, failures will no longer be notified as a persistent message, so integrations need to implement error handling to notify users in case of a failure. Notifications are still added during setup in case of a config issue.
async def async_process_component_and_handle_errors(
hass: HomeAssistant,
config: ConfigType,
integration: Integration,
raise_on_failure: bool = False,
) -> ConfigType | None:
During a reload integrations can use the helpers.reload.async_integration_yaml_config. This helper now also has the ability to raise in case of a failure.
async def async_integration_yaml_config(
hass: HomeAssistant, integration_name: str, *, raise_on_failure: bool = False
Translation support for Exceptions on config validation
A new ConfigValidationError exception class is introduced. It will be raised in case an error occurs during config error handling and raise_on_failure is set to True. It can be re-raised to a ServiceValidationError in case this error is raised during the execution of a service call and a stack trace is not warranted. Translation keys are added to allow localization of the error messages.
Background
