Exception handling during service calls and translation support
Service calls which raise exceptions have until now logged stack traces. Service calls that fail due to incorrect usage, for example invalid input, don't need a stack trace and would benefit from a helpful error message in the user's own language.
To be able to suppress the stack trace in these cases, the new exception type ServiceValidationError
, which is derived from HomeAssistantError
, has been introduced. ServiceValidationError
should now be raised instead of ValueError
when the service fails because it's used incorrectly.
If the service is used correctly but still fails, HomeAssistantError
, or a subclass of HomeAssistantError
other than ServiceValidationError
, should still be raised.
When a service raises ServiceValidationError
, the error message will show in the UI, and in the logs, but the stack trace is logged at debug level. For other exceptions that are raised from a service call (including HomeAssistantError
) nothing changes and a full stack trace is still printed at exception severity.
Integrations should be updated and raise ServiceValidationError
when the the service fails due to incorrect usage, and HomeAssistantError
when it fails for other expected errors, for example a network error. Read more.
Translation support for Exceptions
The HomeAssistantError
exception and its subclasses, including ServiceValidationError
, now accept a translation key to allow localization. Read more. The translation key will be used in cases where the frontend receives information about the exception. The English error message from the translation cache will also be used to log a message to the console if no custom error message is passed to the exception as argument.
Background
- Background discussion.
- Implementation Core PR #102592.
