Deprecate IMPERIAL_SYSTEM unit system and linked constants and properties
· One min read
As of Home Assistant Core 2022.11, the IMPERIAL_SYSTEM is deprecated, replaced by US_CUSTOMARY_SYSTEM.
The is_metric and name properties of a unit system are likewise deprecated and should not be used.
Custom integrations referencing this unit system or these properties will need to be adjusted to use instance checks instead.
Correct:
if hass.config.units is METRIC_SYSTEM:
pass
if hass.config.units is US_CUSTOMARY_SYSTEM:
pass
To avoid confusion with future unit systems, the constants CONF_UNIT_SYSTEM_IMPERIAL
and CONF_UNIT_SYSTEM_METRIC are also deprecated and should no longer be referenced:
- if they were used to compare against the
nameof a unit system, then this is no longer needed. - if they were used for another reason, then local constants should be created instead.
