Making http path registration async safe with `async_register_static_paths`
hass.http.register_static_path is deprecated because it does blocking I/O in the event loop, instead call await hass.http.async_register_static_paths([StaticPathConfig(url_path, path, cache_headers)])
The arguments to async_register_static_paths are the same as register_static_path except they are wrapped in the StaticPathConfig dataclass and an Iterable of them is accepted to allow registering multiple paths at once to avoid multiple executor jobs.
For example, if your integration called hass.http.register_static_path("/integrations/photos", "/config/photos", True), it should now call await hass.http.async_register_static_paths([StaticPathConfig("/integrations/photos", "/config/photos", True)])
The StaticPathConfig dataclass should be imported from homeassistant.components.http
hass.http.register_static_path will be removed in 2025.7
Example
from pathlib import Path
from homeassistant.components.http import StaticPathConfig
should_cache = False
files_path = Path(__file__).parent / "static"
files2_path = Path(__file__).parent / "static2"
StaticPathConfig("/api/my_integration/static", str(files_path), should_cache),
StaticPathConfig("/api/my_integration/static2", str(files2_path), should_cache)
