Forwarding setup to config entry platforms
· One min read
Calling hass.config_entries.async_forward_entry_setup is deprecated and will be removed in Home Assistant 2025.6. Instead, await hass.config_entries.async_forward_entry_setups as it can load multiple platforms at once and is more efficient since it does not require a separate import executor job for each platform.
hass.config_entries.async_forward_entry_setups must always be awaited if it's called while the config entry is being set up to ensure that it finishes before the config entry setup is complete. For more details, review this blog post.
