Device registry WebSocket API changes
· 6 min read
Summary​
This post describes changes to the device registry WebSocket API — the commands and device serialization consumed by the frontend, custom cards, and other WebSocket clients. They stem from two changes to the device registry:
Most clients only read devices through config/device_registry/list, and the new device fields are additive, so no changes are required to keep working — but clients that iterate the device list should be ready to encounter child devices, which are serialized differently. Clients that remove devices, or that inspect a device's config entries, should read on.
New device fields: config_entry_id and config_subentry_id​
Every device returned by config/device_registry/list, and every device in an EVENT_DEVICE_REGISTRY_UPDATED payload, now carries two new fields:
  • config_entry_id — the id of the single config entry the device belongs to.
  • config_subentry_id — the id of the single config subentry the device belongs to, or null.
They replace the previous fields, which modelled a device that could span several config entries and subentries:
  • config_entries — a list of config entry ids.
  • config_entries_subentries — a map of config entry id to a list of subentry ids.
  • primary_config_entry — the id of the device's primary config entry.
The old fields are kept for backwards compatibility and are deprecated; they are scheduled for removal in Home Assistant Core 2027.8. During the deprecation period they are derived from the new values: a device reports config_entries as the single-element list [config_entry_id], config_entries_subentries as {config_entry_id: [config_subentry_id]}, and primary_config_entry equal to config_entry_id.
Update your client to read config_entry_id and config_subentry_id.
Child devices in the device list​
Home Assistant Core 2026.9 introduces child devices (architecture proposal #1414, core PR #178666). A child device is a lightweight logical part of a parent device: it has no hardware or firmware metadata of its own, and it references its parent through a parent_device_id. The parent must be registered by the same config entry and belong to the same config subentry.
config/device_registry/list now returns child devices alongside regular devices, so its result is a mix of two kinds of entry. A child device is serialized with a smaller set of fields:
"id": "child1234",
"parent_device_id": "abcd1234",
"config_entry_id": "wxyz5678",
"config_subentry_id": null,
"area_id": null,
"name": "Left channel",
"name_by_user": null,
"labels": [],
"identifiers": [["demo", "left"]],
"disabled_by": null,
"created_at": 1723987200.0,
"modified_at": 1723987200.0
Compared to a regular device, a child device has no connections, via_device_id, configuration_url, entry_type, manufacturer, model, model_id, hw_version, sw_version, serial_number, primary_config_entry, config_entries, or config_entries_subentries. Clients that read the device list must not assume every entry carries these fields.
The reliable way to tell the two apart is the parent_device_id field: it is present and non-null only on child devices. A regular device carries via_device_id instead.
A child device with no area_id of its own inherits its parent's area, so a client resolving a child device's area should fall back to the parent device when the child's area_id is null.
Two related commands also understand child devices:
  • config/device_registry/update accepts a child device id — setting area_id, disabled_by, labels, or name_by_user — and returns the updated child device in the reduced serialization shown above.
  • config/device_registry/list_linked_devices always returns an empty linked_devices list for a child device, since a child shares its parent's per-config-entry identifier namespace and is never linked to devices of other config entries.
New command: config/device_registry/remove​
A new WebSocket command removes a device by id:
"type": "config/device_registry/remove",
"device_id": "abcd1234"
Because a device now belongs to exactly one config entry, removing it from that config entry removes the device. The command requires admin, and it rejects a composite device id with the error Cannot remove a composite device.
It replaces config/device_registry/remove_config_entry, which took both a device_id and a config_entry_id:
"type": "config/device_registry/remove_config_entry",
That command still works but is deprecated: it logs a warning and will be removed in Home Assistant Core 2027.9. Its config_entry_id parameter is now only used to check that it matches the device's config entry — a mismatch fails with Config entry not in device — and the device is removed regardless of which config entry was passed. Update clients to call config/device_registry/remove and drop the config_entry_id.
Implemented in core PR #178319.
New command: config/device_registry/list_linked_devices​
Because connections and identifiers are now unique per config entry, a physical device supported by several integrations is represented by one device per config entry instead of a single shared device. This command returns the other devices that share a connection or identifier with a given device — the sibling devices representing the same physical hardware under different config entries:
"type": "config/device_registry/list_linked_devices",
Result:
"linked_devices": ["ef567890", "12ab34cd"]
The queried device itself is excluded from the result. This lets a client, for example, link from a device page to the other devices that represent the same hardware. Implemented in core PR #177449.
New command: config/device_registry/list_composite_splits​
When the device registry is loaded, each pre-migration device that spanned several config entries is split into one device per config entry, and the original ("composite") device id no longer refers to a registered device. Composite device ids are still referenced by automations, scripts, dashboards, and target pickers, so this command maps every composite device id to the devices it was split into:
"type": "config/device_registry/list_composite_splits"
Result:
"old_composite_id": {
"split_ids": ["ef567890", "12ab34cd"],
"primary_id": "ef567890"
For each composite device id, split_ids lists the replacement device ids and primary_id is the split that inherited the composite's former primary config entry, or null. Use it to resolve a stored composite device id to a current device — for example, to keep a device picker working when the stored id is a composite id. Implemented in core PR #176693.
The Backwards compatibility section of the companion post describes the rest of the deprecation-period behavior, such as actions targeting a composite device id trickling down to the split devices.
Device registry events​
Clients that subscribe to device_registry_updated events (EVENT_DEVICE_REGISTRY_UPDATED) see two changes, mirroring the Python API:
  • The changes map of an update event reports a device move with the keys config_entry_id and config_subentry_id, replacing the previous config_entries and config_entries_subentries.
  • A device now belongs to a single config entry, so it can no longer lose one config entry while remaining for another. A device losing its config entry is now a remove event rather than an update.
See Device registry events in the companion post for details.
