The core config class has been moved
· One min read
Summary of changes
The definition of the core config class, an instance of which is available as hass.config has been moved from homeassistant/core.py to homeassistant/core_config.py. The move was done to make it easier to read and understand the core code. Custom integrations which currently import Config from homeassistant.core need to be updated to instead import from homeassistant.core_config.
info
Normally, integrations won't need to use the core Config class. But there's been custom integrations that have incorrect type annotations where the config object passed to the integration's async_setup is specified as a Config instance:
from homeassistant.core import Config
async def async_setup(hass: HomeAssistant, config: Config) -> bool:
"""Set up the integration."""
A correct type annotation would be like this:
from homeassistant.helpers.typing import ConfigType
async def async_setup(hass: HomeAssistant, config: ConfigType) -> bool:
Backwards compatibility
Until Home Assistant Core 2025.11, it's possible to import from homeassistant.core, and doing so will log a warning asking users to open an issue on the custom integration's bug tracker.
