Changes to the update entity
 · One min read
Summary of changes
The update entity has been adjusted:
- The in_progressproperty and the corresponding state attribute should now only be aboolindicating if an update is in progress, orNoneif unknown.
- A new property and a corresponding state attribute update_percentagehas been added which can either return anintorfloatindicating the progress from 0 to 100% or None.
- A new property and a corresponding state attribute display_precisionhas been added to control the number of decimals to display in the frontend whenupdate_percentageis afloat.
Backwards compatibility
Until Home Assistant Core 2025.12, a numerical value in the in_progress property will be automatically copied to the update_percentage state attribute.
Documentation and core implementation
See the update entity developer documentation for details.
PRs:
- PR adding the update_percentagestate attribute
- PR adding the update_percentageproperty
- PR adding the display_precisionstate attribute and property
- An example of updating an integration's update entity
