Use Kelvin as the preferred color temperature unit
 · 2 min read
Summary of changes
In October 2022, Home Assistant migrated the preferred color temperature unit from mired to kelvin.
It is now time to add deprecation warnings for the corresponding attributes, constants and properties:
- Deprecate state and capability attributes ATTR_COLOR_TEMP,ATTR_MIN_MIREDSandATTR_MAX_MIREDS
- Deprecate constants ATTR_KELVINandATTR_COLOR_TEMPfrom thelight.turn_onservice call
- Deprecate properties LightEntity.color_temp,LightEntity.min_miredsandLightEntity.max_mireds
- Deprecate corresponding attributes LightEntity._attr_color_temp,LightEntity._attr_min_miredandLightEntity._attr_max_mired
Examples
Custom minimum/maximum color temperature
class MyLight(LightEntity):
    """Representation of a light."""
    # Old
    # _attr_min_mireds = 200 # 5000K
    # _attr_max_mireds = 400 # 2500K
    # New
    _attr_min_color_temp_kelvin = 2500 # 400 mireds
    _attr_max_color_temp_kelvin = 5000 # 200 mireds
Default minimum/maximum color temperature
from homeassistant.components.light import DEFAULT_MAX_KELVIN, DEFAULT_MIN_KELVIN
    # Old did not need to have _attr_min_mireds / _attr_max_mireds set
    # New needs to set the default explicitly
    _attr_min_color_temp_kelvin = DEFAULT_MIN_KELVIN
    _attr_max_color_temp_kelvin = DEFAULT_MAX_KELVIN
Dynamic minimum/maximum color temperature
from homeassistant.util import color as color_util
    # Old
    # def min_mireds(self) -> int:
    #     """Return the coldest color_temp that this light supports."""
    #     return device.coldest_temperature
    # def max_mireds(self) -> int:
    #     """Return the warmest color_temp that this light supports."""
    #     return device.warmest_temperature
    # New
    def min_color_temp_kelvin(self) -> int:
        return color_util.color_temperature_mired_to_kelvin(device.warmest_temperature)
    def max_color_temp_kelvin(self) -> int:
        return color_util.color_temperature_mired_to_kelvin(device.coldest_temperature)
Service call
from homeassistant.components.light import ATTR_COLOR_TEMP_KELVIN
    def turn_on(self, **kwargs: Any) -> None:
        """Turn on the light."""
        # Old
        # if ATTR_COLOR_TEMP in kwargs:
        #     color_temp_mired = kwargs[ATTR_COLOR_TEMP]
        #     color_temp_kelvin = color_util.color_temperature_mired_to_kelvin(color_temp_mired)
        # Old
        # if ATTR_KELVIN in kwargs:
        #     color_temp_kelvin = kwargs[ATTR_KELVIN]
        #     color_temp_mired = color_util.color_temperature_kelvin_to_mired(color_temp_kelvin)
        # New
        if ATTR_COLOR_TEMP_KELVIN in kwargs:
            color_temp_kelvin = kwargs[ATTR_COLOR_TEMP_KELVIN]
