Changes to long term statistics APIs
· 2 min read
Some changes have been made to the long-term statistics-related APIs to reduce response size and database load.
The changes are implemented in this PR.
This affects authors of code calling the following WS APIs:
recorder/statistics_during_period
- A new optional parameter
types
has been added, which allows providing a list of statistics characteristics to include in the response. Possible values are:"last_reset"
,"max"
,"mean"
,"min"
,"state"
,"sum"
- Timestamps
start
,end
andlast_reset
are now an integer number of ms since the UNIX epoch instead of ISO-formatted strings. The new format means the timestamps can be passed directly to jsDate()
constructor. - The
statistic_id
is no longer repeated for each list item in the returned map. This was not used because the return type is a map, keyed bystatistic_id
This affects authors of code calling the following Python APIs:
homeassistant.recorder.statistics.get_last_short_term_statistics
- A new parameter
types
has been added, which allows providing a set of statistics characteristics to include in the response. Possible values are:"last_reset"
,"max"
,"mean"
,"min"
,"state"
,"sum"
- Timestamps
start
,end
andlast_reset
are now andatetime
objects instead of ISO-formatted strings. - The
statistic_id
- A new parameter
homeassistant.recorder.statistics.get_latest_short_term_statistics
- A new parameter
types
,"max"
,"mean"
,"min"
,"state"
,"sum"
- Timestamps
start
,end
andlast_reset
are now andatetime
statistic_id
- A new parameter
homeassistant.recorder.statistics.statistics_during_period
- A new parameter
types
,"max"
,"mean"
,"min"
,"state"
,"sum"
- Timestamps
start
,end
andlast_reset
are now andatetime
statistic_id
- A new parameter
