Relocate dhcp/ssdp/usb/zeroconf ServiceInfo models
· One min read
Summary of changes
To reduce current reliance on optional integrations for names that are in essence used as helpers, the following ServiceInfo models have been relocated:
DhcpServiceInfofromhomeassistant.components.dhcptohomeassistant.helpers.service_info.dhcpSsdpServiceInfofromhomeassistant.components.ssdptohomeassistant.helpers.service_info.ssdpUsbServiceInfofromhomeassistant.components.usbtohomeassistant.helpers.service_info.usbZeroconfServiceInfofromhomeassistant.components.zeroconftohomeassistant.helpers.service_info.zeroconf
To update your integration:
- Replace the import statements as shown in the examples below
- Test your integration with the new imports
The old import locations are deprecated and will be removed in Home Assistant 2026.2.
Examples
# Old
# from homeassistant.components.dhcp import DhcpServiceInfo
# from homeassistant.components.ssdp import SsdpServiceInfo
# from homeassistant.components.usb import UsbServiceInfo
# from homeassistant.components.zeroconf import ZeroconfServiceInfo
# New
from homeassistant.helpers.service_info.dhcp import DhcpServiceInfo
from homeassistant.helpers.service_info.ssdp import SsdpServiceInfo
from homeassistant.helpers.service_info.usb import UsbServiceInfo
from homeassistant.helpers.service_info.zeroconf import ZeroconfServiceInfo
class MyConfigFlow(ConfigFlow, domain=DOMAIN):
"""Handle a config flow."""
async def async_step_dhcp(self, discovery_info: DhcpServiceInfo) -> ConfigFlowResult:
"""Handle dhcp discovery."""
async def async_step_ssdp(self, discovery_info: SsdpServiceInfo) -> ConfigFlowResult:
"""Handle ssdp discovery."""
async def async_step_usb(self, discovery_info: UsbServiceInfo) -> ConfigFlowResult:
"""Handle usb discovery."""
async def async_step_zeroconf(self, discovery_info: ZeroconfServiceInfo) -> ConfigFlowResult:
"""Handle zeroconf discovery."""
