Modernizing Modbus in Home Assistant
· 4 min read
Modbus is everywhere in the modern home: solar inverters, energy meters, heat pumps, and all kinds of industrial equipment that has found its way indoors. Home Assistant has long supported these devices through the YAML-based modbus integration, where users hand-write register maps in their configuration. That integration is not going anywhere, and existing setups keep working. But hand-writing register maps puts the burden of understanding a device's protocol on every user, and it does not fit the config-flow, UI-first direction the rest of Home Assistant has taken.
So we are adding a new way to use Modbus: an integration-based approach, where a device integration owns the device-specific knowledge and the user simply picks their device in the UI, the same as any other integration.
Sharing a connection​
A Modbus connection is a single, exclusive resource: only one party can talk on the bus at a time. A serial (RS-485) bus, or a TCP-to-serial gateway, can carry many devices at once, sometimes from different manufacturers. If two integrations each open their own connection to the same bus, they fight over it, and historically Home Assistant did not support sharing a bus between integrations at all.
The modbus integration solves this by handing out units over connections it shares. A device integration collects its own connection details in its own config flow, the same as any other integration, and asks modbus for a unit on them. Two integrations that ask with equal details get units over one connection, so their requests serialize behind it instead of contending for the bus.
The shared connection is not configured or persisted separately. It exists only while an integration holds a unit, and it closes when the last consumer's config entry unloads. That keeps the user experience where it belongs — you set up your heat pump, not a bus — while still giving the bus a single owner. The Modbus developer documentation covers how to ask for a unit, with example code.
A standalone library​
The connection abstraction underneath modbus lives in modbus-connection, a new library we designed for this purpose and published on PyPI. It is not bound to Home Assistant and can be used standalone in any Python project. It presents a common, backend-neutral interface, so device library authors write against one API regardless of the underlying Modbus implementation, and it ships a device-modelling framework and a pytest plugin to make building and testing a device library straightforward.
This keeps concerns where they belong. A device library is a normal PyPI package that knows how to talk to a specific device, and a consuming integration in Home Assistant wires that library up to a shared connection and exposes entities. Both can be developed and tested independently.
For more background, see our research.
Let's get building​
With these new building blocks in place, it is now possible to turn a collection of YAML configuration for Modbus into manufacturer-specific integrations that people can set up via the UI. If you're (interested in) working on this, stop by the #modbus channel on the Home Assistant Discord and we'll be happy to help.
If you're using an AI agent, you can give it the following prompt:
I want to create a new integration for Home Assistant using the new Modbus Connection integration as documented here: https://developers.home-assistant.io/docs/modbus/introduction
The YAML we want to turn into a device library can be found here: TODO INSERT LOCATION OF MODBUS YAML!
The deliverables of this task are going to be 3 folders:
