Shared config flow abort reasons are translated centrally
· 2 min read
As of Home Assistant Core 2026.10, the homeassistant integration can translate abort reasons that every integration words the same way. If you're today linking from a local translation key, for an abort reason, to a shared translation key under the homeassistant integration, you can instead just rely on the shared translation key under the homeassistant domain directly. This is done by default in some helpers and can also be done explicitly by setting the translation_domain parameter when aborting the flow.
What to do​
  • Delete the keys below from the abort sections of strings.json, including those under config_subentries, only when the abort uses the homeassistant translation domain.
  • The helpers listed below use the central translation domain automatically.
  • If your code passes one of these reasons to async_abort or AbortFlow, pass the homeassistant translation domain before deleting the local key. Without that domain, retain the local key. See Raise one yourself.
When an abort uses the central translation domain, the frontend resolves the reason from that domain and does not use a local key.
Default reasons​
ReasonRaised by
already_in_progressasync_set_unique_id, discovery without a unique ID
single_instance_allowedsingle_config_entry, DiscoveryFlowHandler, WebhookFlowHandler
no_devices_foundDiscoveryFlowHandler
cloud_not_connectedWebhookFlowHandler
reauth_successfulasync_update_reload_and_abort, async_update_and_abort
reconfigure_successfulasync_update_reload_and_abort, async_update_and_abort, also for subentries
authorize_url_timeoutAbstractOAuth2FlowHandler
missing_credentialsAbstractOAuth2FlowHandler
no_url_availableAbstractOAuth2FlowHandler
oauth_errorAbstractOAuth2FlowHandler
oauth_failedAbstractOAuth2FlowHandler
oauth_implementation_unavailableAbstractOAuth2FlowHandler
oauth_timeoutAbstractOAuth2FlowHandler
oauth_unauthorizedAbstractOAuth2FlowHandler
user_rejected_authorizeAbstractOAuth2FlowHandler
Explicit translation domain​
Pass the domain that owns the string. Both async_abort and AbortFlow accept it.
from homeassistant.core import DOMAIN as HOMEASSISTANT_DOMAIN
return self.async_abort(
reason="no_devices_found",
translation_domain=HOMEASSISTANT_DOMAIN,
This works in config flows and subentry flows. Options flows look in the options section, which the homeassistant integration does not have.
Keep your own wording​
Only needed if you word a reason differently on purpose:
  • Pass reason to async_update_reload_and_abort or async_update_and_abort, even with the default name.
  • In an OAuth2 flow, pass translation_domain=DOMAIN.
Aborts that core raises by itself, like already_in_progress, always use the central string, to keep a customized string there, overwrite the steps that produce the strings upstream.
