Use Config Entry exceptions in integration migration method
· 2 min read
Integration migration async_migrate_entry method can now raise config entry exceptions instead of only being limited to return False. This is preferred to provide more context and being translatable.
Integrations that fetch data from other services during migration can raise ConfigEntryNotReady to have the migration retried automatically later (as during setup), which helps with timeouts and other errors that may resolve on their own.
By returning False or raising any other exception than ConfigEntryNotReady the migration stops and the config entry state is set to migration_error which is a non-recoverable state. This previously required the user to restart Home Assistant to retry the migration. The new correct way to handle it is to create a repair issue. After the user fixes the issue, call hass.config_entries.async_retry_migration(entry_id) to retry the migration.
More info in the config flow documentation.
Example migration function which raises if client has an issue
The migration function lives in the integration's __init__.py.
from homeassistant.helpers.issue_registry import IssueSeverity, async_create_issue
async def async_migrate_entry(hass, config_entry: ConfigEntry):
"""Migrate old entry."""
_LOGGER.debug("Migrating configuration from version %s.%s",
config_entry.version, config_entry.minor_version
if config_entry.version == 1:
try:
new_info = await client.get_info()
except ConnectionError as exc:
raise ConfigEntryNotReady(
translation_key="key",
translation_domain=DOMAIN,
) from exc
except AuthenticationError as exc:
async_create_issue(
hass,
DOMAIN,
f"migrate_could_not_auth_{config_entry.entry_id}",
is_fixable=True,
is_persistent=False,
severity=IssueSeverity.ERROR,
translation_key="migrate_could_not_auth",
translation_placeholders={"title": config_entry.title},
data={"entry_id": config_entry.entry_id},
raise ConfigEntryError(translation_key="migrate_could_not_auth") from exc
new_data = {**config_entry.data, "some_data": new_info["some_data"]}
hass.config_entries.async_update_entry(
config_entry, data=new_data, version=2
_LOGGER.debug("Migration to configuration version %s.%s successful",
config_entry.version, config_entry.minor_version,
return True
Example repair which will retry the migration
The repair flow lives in the integration's repairs.py.
class MigrationRepairFlow(RepairsFlow):
"""Handler for a migration repair flow."""
def __init__(self, entry_id: str) -> None:
"""Initialize the flow."""
self.entry_id = entry_id
async def async_step_init(
self, user_input: dict[str, Any] | None = None
) -> RepairsFlowResult:
"""Fix the issue and retry the migration."""
if user_input is not None:
# TODO: Do whatever is necessary to fix the issue,
# for example update the config entry data
await self.hass.config_entries.async_retry_migration(self.entry_id)
return self.async_create_entry(data={})
return self.async_show_form(
step_id="init",
data_schema=probatio.Schema({}),
async def async_create_fix_flow(
hass: HomeAssistant,
issue_id: str,
data: dict[str, str | int | float | None] | None,
) -> RepairsFlow:
"""Create flow."""
if issue_id.startswith("migrate_could_not_auth_"):
return MigrationRepairFlow(data["entry_id"])
